Preload Procedure for KW Variant 3?
Old Sep 23, 2007 | 07:01 PM
ONO's Avatar
ONO
Thumbs up Preload Procedure for KW Variant 3?
Hi, guys
Can someone please explain to me what is the proper procedure to "preload" the KW variant 3 coilover?
From using the search funciton, I have come to the following steps:
1) Screw in the bolt into the clevis of the coilover, but do not torque it yet.
2) Put the jack stand at the jack point and use the jack to raise up the control arm to "preload" the suspension or raise it up from the rotor?
3) Adjust the ride height by lowering the spring collar. KW suggests the front axle setting is 20-60 mm and the rear axle is 40 mm. What is the recommended "preload " setting for the street?
4) Torque the bolt according to the OEM spec
Any suggestions to make this "preload" procedure properly?
Thanks in advance.
Old Sep 26, 2007 | 06:56 PM
ONO's Avatar
ONO
Anybody???
Old Sep 28, 2007 | 04:39 AM
Pruhnke's Avatar
https://www.s2ki.com/forums/index.php?showtopic=259346
Have you looked at this write up?
When I installed mine I had the car up on jackstands on all for corners and then placed the jack under the damper and the compressed the damper until the car just lifted of the jack stand. I then lowered slightly and torgued the bolt. I repeated this process on the other three dampers.
Hope this helps.
Old Sep 29, 2007 | 05:36 AM
Standing Room Only's Avatar
If I recall, when I installed mine and loaded the suspension, the A-Arm was almost level with the ground and car was just @ 1/4" off off the jackstand.
Old Sep 29, 2007 | 11:45 AM
Boofster's Avatar
Hope this helps.
Old Sep 30, 2007 | 10:37 PM
ONO's Avatar
ONO
Thank you for your input on this subject.
YCW
Sep 5, 2018 08:47 PM
shortguy
Apr 5, 2015 04:05 PM
Project SSAP1
Sep 13, 2005 05:20 AM
deepee
Oct 4, 2004 01:40 PM
