Question for those with KWs
I've been noticing the ride comfort is starting to suck. It is very harsh over bumps, crashes and jarrs over expansion joints. Not like what it was when I first installed it a year ago. It seems like its only the rear shocks though, the front of the car seems to glide over bumps nicely. The rears constantly make noise and I can see the top of the shock (the rubber part below the 2 nuts) move up and down quite a bit.
Has anyone else noticed a degradation in ride quality? It's so bad now that I know exactly what lanes to be in on the freeway to avoid bumps. I have the rear rebound near full soft , bump is close to the middle of range.
Originally Posted by twohoos,Oct 19 2006, 04:18 PM
Try more rebound, less compression.
Leaks? Mileage? Could be time for a rebuild.
Is it normal for the rebound adjuster and top of the shock to move in and out a lot?
Not sure if it will help, but you might try *resetting* the damper by closing the valves all the way and then setting them back where they were before.
The shaft shouldn't be noticeably moving up and down...that sounds like a top mount issue.
deegaw11
Mar 15, 2011 05:11 PM
