Question for those with KWs
Old Oct 19, 2006 | 03:03 PM
pantyraider's Avatar
Default Question for those with KWs
I've been noticing the ride comfort is starting to suck. It is very harsh over bumps, crashes and jarrs over expansion joints. Not like what it was when I first installed it a year ago. It seems like its only the rear shocks though, the front of the car seems to glide over bumps nicely. The rears constantly make noise and I can see the top of the shock (the rubber part below the 2 nuts) move up and down quite a bit.
Has anyone else noticed a degradation in ride quality? It's so bad now that I know exactly what lanes to be in on the freeway to avoid bumps. I have the rear rebound near full soft , bump is close to the middle of range.
Old Oct 19, 2006 | 03:18 PM
twohoos's Avatar
Try more rebound, less compression.
Leaks? Mileage? Could be time for a rebuild.
Old Oct 19, 2006 | 03:23 PM
Didn't notice any leakage last time I looked there. Probaby only 5 - 7k miles.
Is it normal for the rebound adjuster and top of the shock to move in and out a lot?
Old Oct 19, 2006 | 04:11 PM
mikegarrison's Avatar
You might have a problem with that rubber bushing up there, I suppose.
Old Oct 19, 2006 | 05:49 PM
CRDMS1's Avatar
Not sure if it will help, but you might try *resetting* the damper by closing the valves all the way and then setting them back where they were before.
The shaft shouldn't be noticeably moving up and down...that sounds like a top mount issue.
3312DC's Avatar
My left rear blew.... hopefully that doesnt happen to you
although being in california, id take them back to KW, have them look at them.
Sebring AP1
Apr 14, 2014 04:01 PM
adrais
Nov 29, 2011 08:37 AM
deegaw11
Mar 15, 2011 05:11 PM
Reco2k
Feb 9, 2010 03:55 AM
Robs05S2000
Jan 1, 2009 10:46 PM
