Quick Brake Question
Old Oct 29, 2012 | 11:45 PM
nofearofdanger's Avatar
Default Quick Brake Question
Will these fit a 2002 AP1? The listing says 2003-2005, but I've seen a slotted RDA for 1999-2003 on sale as well. Surely if its inclusive 1999-2003 then it should fit a 2002?
Hopefully someone can clarify the matter:
Honda S2000 2003-2005
Front Slotted Rotor x2
Part #RDA7594S
Rotor Type: Vented
Diameter: 282mm x 23mm
No of Bolt Holes: 5
Secondly, which type of rotor will the 2002 have?
The listing says: be aware that the S2000 was produced with 2 different Front rotor sizes, please measure your current rotor diameters before purchasing and send us a message to let us know which you want sent.
The most common AP1 and some AP2 models size is 300mm diameter with a 70mm hub hole (Part number RDA7600)
Also available is 282mm diameter with a 64mm hub hole for later AP2 models (Part number RDA7594)
Thanks for your help in advance.
Old Oct 30, 2012 | 12:24 AM
psychoazn's Avatar
As far as I know, all s2k rotors are universal to all years...
Old Oct 30, 2012 | 02:27 AM
Ok - I will take your word for it. Just bought some RDA slotted fronts for an absolute steal.
140 landed to my house
Old Oct 30, 2012 | 02:36 AM
Oh crap - I got the 282 x 23mm
mine's an 02
Any ideas if this will work?
Old Oct 30, 2012 | 02:47 AM
Shouldn't all the front rotors be 300mm? Perhaps the listing is wrong?
http://cgi.ebay.com.au/ws/eBayISAPI....ht_1874wt_1141
Old Oct 30, 2012 | 03:18 AM
Ok - so apparently from 03 and up the front rotor size went down to 282mm. This seems very counter-intuitive to me. I've asked if I can get a refund.
Just a heads up
99-2002 = 300mm front rotors
2003-2005 = 282mm apparently.
Old Oct 30, 2012 | 05:30 AM
macr88's Avatar
All years are the same in the US and I can't imagine it would be any different elsewhere.
Only difference was pad compound but that appears to have changed, now there's only one.
I believe the info below is correct for a front rotor
5 x 114.3 mm bolt pattern
299.6 mm disc diameter
12.6 mm bolt size
23 mm minimum thickness
http://www.discountbrakes.com/shop/?N=0&Nr=AND%28category%3ABrake%2Cuniversal%3A0%29& PN=0+2253&VN=4294967114+4294962818+4294962710+4294 967132+4294967090&Nr=AND(category:Brake,universal: 0)
Old Oct 30, 2012 | 06:58 AM
Then how come they are selling a 282mm diameter rotor for the front?
Old Oct 30, 2012 | 01:42 PM
chetly's Avatar
Ask them...
Old Oct 30, 2012 | 02:50 PM
afzan's Avatar
Why do you believe them? Check any other resource and you will see that they are wrong
and what does this have to do with racing and competition?
