Racing wheel lug nuts
Hey guys,
Hopefully you can help me out. I have a set of iforged aero 3 piece aluminum wheels and have recently upgraded to a ford super 8.8 rear end with 1k whp DSS axles. This has changed the hubs to larger splines and also uses arp extended wheel studs for racing. My issue is i have no clue what open ended lug nuts to go with. They do need to be tapered end for these rims i believe and i want a good set of strong lug nuts, yet still look stylish and in black. Anyone know the best/strongest brand out there? Also, should I be using steel or aluminum lug nuts on the aluminum wheels?
Here is a picture of the stud/nut area on the wheel. It almost looks as though tapered or straight through lugs could be used. Can anyone confirm?
Thanks for the help.
i use bwr (black works racing) steel open ended extended lugs. worked fine for me the past 3 years. dont get anything aluminum for track stuff. they come in all the colors, black,red,blue, neochrome, etc and are cheap enough to use as a consumable and not feel bad about it
Spoolin (02-19-2019)
Use Mcguard steel lugs on my Civic expensive but great quality
Thanks a ton guys, I'll check these out.
Ive been using 949 Racing lug nuts for the past 3 months and no problems so far. These are definitely light and from what I've heard, they are pretty strong. But don't quote me on that last part.
RedCelica (02-21-2019)
aluminum is fine, don't over torque them.
+3 for 949 lugs. Work great and impact friendly.
I've used 949 extended open aluminum lugs with my impact tools on ARP extended studs. They are about 5 years old. I may replace them soon as preventive maintenance but I haven't had any issues yet.
Spoolin (02-21-2019)
