Rear tow hook help
Last fall I ended up on a tire wall when my wheel sheared off. While towing my car off the wall they snapped the Oem hook leaving the stud in place. I've tried several times to get the stud out but it's jammed in place and won't budge. Last easy out attempt resulted in a broken bit now lodged in the pilot hole. Has anyone found an acceptable substitute to mount a rear tow hook? I need something that is track worthy...not bling. Also...where is the best place to mount it on the rear? Any help is appreciated. My track car is a 2006.
You could maybe try doing what this guy did but use a strap instead, you'll likely need to make a slot in your rear bumper. Or get a used bumper bar on eBay
https://www.s2ki.com/forums/s2000-mo...tions-1214112/
dws2000
Dec 24, 2004 05:43 AM
