Rear wing
Old Jul 30, 2011 | 12:38 PM
  #21
markhs2's Avatar
Originally Posted by psychoazn
As for standing on the wing... it's a marketing gimmick. The wings are capable of more downforce than 200 lbs... That being said, I'm sure the kognition can support far more than 200 lbs. Probably at least 5x more.
If you take a pair of size 12 shoes, it's about 90 sq/in or .66 sq ft, therefore a 200lb person standing is exerting approx 300 lbs/sq ft. Its actually more than that because size 12 will overhang the 10" chord and therefore concentrate the weight more.
The 68" Kognition wing is about 4.74 sq ft so that's 300lbs x4.74 sq ft = 1422 lbs over the surface of the wing.
Keep in mind he's standing at that force in the center of the wing, the most vulnerable area.
Test it; Just put a piece of 3/8" wood on a couple of pieces of 2x4 on edge, 30" apart, where the uprights would be and try it. I did it with 1/2"x 5"wide plywood (didn't have a 3/8" piece). No problem lying on it. Stand on it and snap!
Marketing, yes
Gimmick, no
BTW Mike will make the wing any width you want. From as small as you like up to 78".
Old Oct 4, 2011 | 05:04 PM
  #22
turbo8765's Avatar
Do you have any pics of the mount? Do you know anyone who is using this wing?
jetguy
Jun 16, 2016 06:45 AM
tre3478
Nov 4, 2014 11:32 AM
Dicktp
Apr 29, 2014 03:48 AM
