Recommendations on Front Bumper
anyone have an answer or guess?
and i'm assuming you can generate the same amount of downforce with canards that you can with a splitter right? ( obviously lots of variables, but lets just assume a general statement, ie is it possible ).
thanks.
i was doing some more research on here and it looks like a lot of members are saying they are used for slightly different reasons. the canards primary reason being vortex generators to direct air to the outsides of the car.
also found that canards require some very precise mounting.
Originally Posted by spunkysandoval,Sep 22 2009, 10:35 PM
Another good shot
i would say:
cr front bumper + splitter + canards will generate you max downforce u ever wanted!
however, to run this setup you need at least a voltex wing!
and you can also determine how much downforce u want though how far out the splitter is =) (fyi mine is 3" lip)
Originally Posted by CourageOO7,Nov 10 2009, 12:39 PM
Non sequitur but I don't understand the purpose of this vertical mount in this picture. Correct me if I'm wrong, but the purpose of a vertical mount setup is to distribute flow to both the radiator and the intercooler. Hence, shouldn't he have the radiator on the bottom and the intercooler on the top like so: < ? Otherwise, you'd just be reducing flow to both and the only benefit I can see is improved flow throughout the engine bay?
Other than that, I have no idea.
Originally Posted by momofoolio,Nov 10 2009, 01:43 PM
i would say:
i might raise the front of the car up 1/4'' or so and go that route.
... but I don't understand the purpose of this vertical mount in this picture...
The purpose then was because they fed their ITBs from the left side of the car and needed to fit a taller/narrower radiator under the low hood of the S.
Plus others have pointed out that having the radi at an angle slows the air speed and provides more cooling (most open wheel have angled radiators).
Not to mention that the C-west hood is fully ducted to remove air from the Rad.
That said...
Once the GReddy turbo was installed, I'm sure that all changed.
But they might have kept the modified angled rad and just added the IC in front...
