Remove Rubber from Stock Hat KW V3?
Old Dec 24, 2012 | 01:32 PM
robrob's Avatar
After looking closely at the rubber cushion I think I'll heed TWF's warnings and just leave them in.
Old Dec 24, 2012 | 01:51 PM
boyguan's Avatar
On my Eibach they are metal to metal and I don't think it will make a difference. Many of the High end coil overs don't have those on them and are metal to metal
Old Dec 24, 2012 | 01:52 PM
boyguan's Avatar
Sorry but I forgot to mention the size of the springs is about the same size as the metal
Old Dec 24, 2012 | 01:55 PM
TWF's Avatar
TWF
Does your spring have sideway move or is hat made to fit spring?
I assume hat on those high end units is nice and flat with perfect fit.
Old Dec 24, 2012 | 01:57 PM
robrob's Avatar
I would prefer metal-to-metal but only if the spring cap is captured in the shock hat and not allowed to slide around which would happen if I simply removed the hat's rubber spring cushion. In my picture of the shock hat above you can see how the cushion surrounds the KW spring cap.
Old Dec 24, 2012 | 02:08 PM
TWF's Avatar
TWF
You need custom piece if you want metal on metal. There are 2 rivets under the rubber. You don't have nice flat surface. Why don't you get hats with bearings if that is what you like to have?
Old Dec 24, 2012 | 03:38 PM
robrob's Avatar
Cost. I'd love to have some nice pillow ball shock hats but I don't believe the cost/benefit ratio makes it a worthwhile upgrade.
Old Dec 24, 2012 | 03:45 PM
TWF's Avatar
TWF
Find plastic/delrin tube with OD slightly bigger than hat and ID about 1/2" smaller than spring ID and I will make you caps
Old Dec 25, 2012 | 04:16 AM
robrob's Avatar
Thanks but if I could find that I'd make them myself on the lathe in the garage but I'll keep my eyes open for a suitable plastic tube.
Old Dec 25, 2012 | 12:02 PM
TWF's Avatar
TWF
You can buy piece of plastic new for about $100 to do 4 of them. Mcmaster has some they sell by foot.
When I did my for helper springs I found piece on ebay. It was solid 4.5" rod so I had to machine more but price was right. With tube you could make all 4 in about hour
