Removing the AC
None, tho the benefit of weight savings can be expressed in terms of HP when compared to a car of stock weight. It goes something like this, every 10 lbs of weight savings in a lite S2K is equivalent to 1 HP extra in a stock S2K. I probably have that 10lbs = 1hp figure wrong but its probably pretty close.
-as I understand it-
It changes and depends where you start measuring from.
If you start w/ a stock at 2750lbs & 240hp is 11.48 lbs per hp. So every 11.48 lbs you remove would be the same as adding 1 hp to a 2750lbs car.
Is there a DYI on this by any chance because i wanted to remove my AC hardware, keep everything needed for heat as i drive in a cooler climate for about 3 months that i drive the car and i hoenstly have no idea where to start when doing such a project
