resurface hot spotted rotors?
I resurfaced my first set of rotors that I used to destroy a set of ferodo DS2500 pads with and continued to use them. 25k total miles, 8 track days, countless autocrosses before I finally destroyed them by running them w/ backing plates
Originally Posted by jguerdat' date='Feb 9 2005, 03:17 AM
Originally Posted by DJHohum' date='Feb 9 2005, 09:32 PM
heat spots cannot be removed by resurfacing the rotors. the actual heat spots are hardened and cannot be removed by the brake rotor lathe.
just replace them.
just replace them.
The only fix for extensive uneven deposits involves dismounting the discs and having them Blanchard ground - not expensive, but inconvenient at best. A newly ground disc will require the same sort of bedding in process as a new disc. The trouble with this procedure is that if the grinding does not remove all of the cementite inclusions, as the disc wears the hard cementite will stand proud of the relatively soft disc and the thermal spiral starts over again. Unfortunately, the cementite is invisible to the naked eye.
Taking time to properly bed your braking system pays big dividends but, as with most sins, a repeat of the behavior that caused the trouble will bring it right back.
Complements of Carrol Smith
I'm trying to isolate the cause of my brake fade, and ran across this thread.
I'm on Carbotech XP 10/8 w/ATE Blue and my brakes faded on me earlier than usual last week and I'm wondering if that was because the pad deposits left on the rotors caused excess friction/heat? I bled my brakes afterward and found no air in the brake lines, so I'm puzzled as to why my brakes faded. I'm new to tracking and I'm getting faster and braking harder so I'm not sure if what the fade is attributed to...does brake fade only occur once air is introduced in the brake lines, or can it happen before the boiling point?
I should also point out that my brakes did pulse a bit. I will try garnet paper to clean up the rotors, but I'm still cautious about it and I'd hate to have brake problems prematurely ruin my next track day. Any other suggestions? Is it time to move on to Cobalts?
