rhouck Review: Urge AP Racing BBK
Old 05-30-2013, 11:09 PM
  #121
psychoazn's Avatar
WedsSport 17x9 +49 TC105N clears the kit
Old 05-30-2013, 11:23 PM
  #122
boyguan's Avatar
How much room on the weds? That was going to be my combo
Old 05-30-2013, 11:42 PM
  #123
psychoazn's Avatar
Around 2mm. If you want to play it safe, ebay some 3mm spacers.
Old 06-15-2013, 04:55 PM
  #124
odb812's Avatar
Where are you guys getting your replacement rings?
Old 06-15-2013, 09:30 PM
  #125
Sebring AP1's Avatar
NO WAY!?>? Mike are you serious? I just sold the damn wheels too
Old 06-16-2013, 07:40 AM
  #126
99SH's Avatar
From the source. AP Racing # CP3862
http://www.essexparts.com/catalogsea...sult/?q=cp3862
Jess did mention he has a few sets floating around
Old 06-16-2013, 05:44 PM
  #127
Sponsor
Urge's Avatar
We also sell these and provide replacements for many of our customers.
__________________
Old 06-17-2013, 05:43 AM
  #128
Former Sponsor
JRitt@essex's Avatar
Hi Guys,
Very nice review and detailed discussion gentleman. I just wanted to throw a few more cents in...
First, here is an article that discusses some benefits of owning a big brake kit that you may not have considered.
Also, below is something I posted on the FT86 forum regarding the Essex/Urge/AP Racing system vs. StopTech. It seems to be appropriate here:
I'm uniquely qualified to answer this question...I was the sales mgr. at StopTech from 2003-2008, and I now work for Essex (the importer and distributor for the components used in the AP T1 kit). Here's the breakdown as I see it.
Calipers
Anti-knockback springs
AP Racing has them, StopTech doesn't. People severely underestimate how valuable these springs are. After going through S turns, you'll have a much lower pucker factor in the next brake zone with the springs installed.
Piston type
StopTech= cast aluminum
AP= machined stainless steel
Stainless is far superior at keeping heat out of your brake fluid
Weight
ST-40 weighs 7.94 lbs. without pads
AP Racing CP8350 weighs 4.8 lbs. without pads...roughly half of the StopTech's
Dust Boots
StopTech is a street caliper, and as such uses dust boots. CP8350 has none. If you've ever run dust boots on the track, you'll find that they burn up and cause a big mess almost instantly. Their only value is if you're driving on winter or debris/dirty roads. As soon as they go on track they essentially lose all value.
Seals
Both calipers have quality, high temp seals.
Hydraulic protection
ST-40 has none, while the CP8350 has it for both bleed screw and crossover tube. This feature protects the hydraulics from track debris, and when you're swapping wheels.
High quality forged aluminum
The caliper bodies on the ST-40 and CP8350 are both high quality forged aluminum parts.
Pad choice/cost/size
Both calipers have tons of pad options. The pad surface area on the ST-40 is slightly larger, but they are a few mm thinner than the pads used in the CP8350. Overall pad mass is very comparable, but the nod goes to the thicker pads in terms of wear rate. On average, pads for the AP caliper are $100 less per set for the same compound.
Stainless Steel hardware
Both calipers have good stainless steel hardware.
Finish
StopTech= painted. Look pretty, but will not look as good after hard use. Paint and powdercoat tends to change color dramatically at track temps. If you're driving through road salt, they will be better protected than anodized.
AP Racing= anodized. Look 'racier' (like what you see on full-blown race cars like C6R) and do not color shift nearly as much.
Rebuild Service
Essex offers a lifetime professional reconditioning service. For a $125/caliper you can send your calipers to Essex and have them rebuilt by the same techs who service NASCAR and ALMS teams. StopTech can rebuild, but I'm not sure how formalized their procedures, policies, and prices are at this time.
Discs
Quality and Price
Both companies offer high quality discs for the kits in question, at very similar prices. The AP's are actually a bit cheaper for replacement iron. Discs from both manufacturers are quality castings that are crack resistant and will last a long time under heavy track use. Due to the enormous number of variables, it's tough to say one would give you more longevity than the other.
Disc hats
Both have a quality design and are made from aircraft grade aluminum. Both are optimized for weight and airflow.
Brake Lines
Both systems come with a high quality set of brake lines.
I actually ran the StopTech ST-60 system on my C5 Z06 while I worked at the company (and their ST-40 system on my 350Z). It is an excellent system with high quality parts. That said, the AP kit we put together was based with that system firmly in our sights. We tried to look at every piece of that system and produce something that eclipsed its performance, all while keeping the costs down. I believe we have succeeded...more technology, higher specification, lower running costs, etc.
Old 06-17-2013, 02:26 PM
  #129
pgss2k's Avatar
From what I can gather and the searching I have tried my 17x9 63 ET 949 wheels are going to have to go for me to consider any BBK be it this one or any other, am I correct?
Old 06-17-2013, 09:52 PM
  #130
MMisencik157's Avatar
Originally Posted by JRitt@essex
Hi Guys,
Calipers
Piston type
Weight
Dust Boots
Seals
Finish
Rebuild Service
Discs
Quality and Price
Disc hats
Brake Lines
I just wanted to quickly point out that some of these things are more of an issue on other cars. The S2000 has never really been know to have a problem with pad knockback. At least Ive never experienced it with neither stock nor ST-40. SS pistons are better at keeping heat out of the fluid but again any BBK on the S2000 will get rid of enough heat that it doesn't really matter. Ive been using the same Motul RBF600 for about a year (11 track days so far and haven't experienced fluid fade with the ST kit even with pad material being less than 5mm on my last outing. I could see this being more of a problem on cars that are heavier, more powerful, and using wider/stickier tires though. I have red painted calipers and they have hardly color shifted and the dust boots look as good as new. The paint ST uses must be different than the Brembo calipers on the EVO and STI that color shift horribly.
Im not the fastest or most experienced driver but I do run in the open groups and would like to think I run a descent pace. Some of my personal bests with a 2.5 point (S2K challenge) car:
2:09.306 @ BW CCW1
2:05.1xx Thunderhill bypass (hot day)
2:06.79x @ Thunderhill
1:55.97x @ Sonoma
Yes, well at least any BBK designed for use on a road course.
Quick Reply: rhouck Review: Urge AP Racing BBK
