Rollbar for my AP1
Old Nov 8, 2009 | 07:43 PM
skys2000's Avatar
Default Rollbar for my AP1
I'm planing to built a Rollbar for my AP1.there's a shop in South El Monte named Pit Garage ,they do race car fabrication that can built the bar for me less $$$ than the cusco one. but they hav 2 kind,not sure which one should I get.will u guys perfer Weld in rollbar or the Bolt in one?
and 4pt single dagonal or double dagonal?
Old Nov 9, 2009 | 02:18 PM
SILAP1's Avatar
Im welding my bar in this winter after seing a post of a bolt in mustang bar . Its totally up to you , welded is stronger but not to easy to remove . I would go welded with single diagonal bar .
Old Nov 9, 2009 | 02:31 PM
f20kills's Avatar
I cant see how if the bar was welded the end result would have been different for that mustang...
Its all about the mounting points...not how it gets mounted I would think.
Old Nov 9, 2009 | 06:02 PM
Stratocaster's Avatar
You can weld it in places that have structual support. You can't bolt one in the same place.
Old Nov 9, 2009 | 06:28 PM
f20kills's Avatar
My point is that the bar only mounts one way....whether its welded or bolted, the end result would have been the same (Mustang, the OP example).
As for other/custom bars....yes, I agree with what youre saying.
Old Nov 9, 2009 | 07:51 PM
I agree. However, the location that the Elda/Hard Dog bar mounts, the main hoops, is on a frame location. I don't think welding it in the same location will give it any additional support. Our car is very uncommon in that we have a high frame behind seats. The Mustang does not. The frame rails run only on the outside, and bolting it those the sheet metal only weaken it.
After seeing that, I am going to make a few changes to my cage. It was custom, but I did not like a few of the mounting locations. I am going to remove and rebend a few of the bars to properly tie into the frame. I too have a sheet metal location for a few of my bars.
Old Nov 9, 2009 | 10:49 PM
rob.ok's Avatar
Do something like this....It'll do the trick.
Old Nov 10, 2009 | 05:07 PM
jimtway1's Avatar
I have the Hard Dog bolt-in roll bar. To fit the rear backing plates, you have cut into to the rear wheel wells.......very sketchy. Plus it took a ridiculous amount of time to fit it.
Next time, I'd just weld a bar in.
Old Nov 10, 2009 | 05:16 PM
f20kills's Avatar
I think Im just going to weld my front bracket in for my HD.
Old Nov 10, 2009 | 05:30 PM
Vitt's Avatar
rob.ok, nice bar. Where did you get it done? In SoCal?
