Is s2000 missing steering feedback?
Even the simplest thing like tires makes a huge difference in steering feel/response. My S2000 feels like a Honda Civic with winter tires. When I go back to my stock wheels/tires it feels like I just jumped into a go-kart again.
Originally Posted by sfphinkterMC,Nov 11 2004, 04:23 PM
no, you want power steering...even Michael Schu uses it
its the variable assist and electric part that probably blows
swap in an RX-7 rack and let me test it....its supposed to fit
Sorry to disagree with you but I think that whether or not an F1 car has PS is irrelevant to this discussion.
If you are correct, that the variable assist and electric part probably blows, then disconnecting the EPS should stop the blowing, no?
).Steve
OK, it's really easy to disconnect the fuse that runs the EPS motor. It takes one minute. Open your hood. Locate the auxiliary under-hood fuse box (it's right next to the brake fluid reservoir). Open it up. Use a Philips head screwdriver to take out the 70 Amp EPS fuse.
Drive your car. You'll notice two things: first, your EPS light stays on; second, IT'S REALLY HARD TO STEER!!!
My opinion after driving w/o EPS: there is certainly no dramatic increase in road feel. Maybe a little (like 2% more). But it certainly requires quite a bit more effort to take a turn, especially at any speed below 30MPH.
So, if there is a problem with the steering feel in the S2000, in my opinion, it's not caused by the EPS.
This is probably fine to do as a test, but I wonder if it might not be such a great idea in the long term. A car designed with PS does not usually have a lot of stress on the components from the steering wheel to the PS mechanism.
Peter
Peter
Originally Posted by TrueDrezzer,Nov 10 2004, 05:14 PM
Hmm, doesn't the NSX have EPS as well?
///Robin
///Robin
).ron
