S2000 ready to drive!
Old Sep 3, 2009 | 06:25 PM
robinson's Avatar
I was just saying, that he's surprised at the handling after adding rear camber, and I was just pointing out that he could go back, or reduce it a bit, higher than before, and that would probably solve his "problem".
However, I would agree with the rest of the comments. Max the front traction, then max rear and or tune the balance with rear traction, like Rob states, temps and pressures are your friend.
Old Sep 4, 2009 | 03:46 AM
HH-S2000's Avatar
i am running front and rear 600 in-lbs spirng rates.
is it to soft???
i can order harder springs, that is not the problem if i order, i will get the springs in 48 hours
so, thanks for all the good and helpfull posts.
i will start with -3 camber front and rear and than fine tune it.
toe at the rear i mean 0.20 not 20 :=PP
can someone told me which caster and toe would be the best compromise??
ES2K
Apr 14, 2015 08:41 AM
sillyboybmxer
May 23, 2011 06:23 AM
dan_uk
Jan 4, 2010 10:25 AM
s2kpearlwhite
Feb 26, 2009 12:21 PM
owenxguo
Apr 30, 2007 08:43 AM
