S2000 Stock class autocross information
Old Feb 5, 2005 | 12:08 AM
PedalFaster's Avatar
Minor update:
Originally Posted by PedalFaster' date='Jan 1 2004, 01:41 AM
v1.2 - Incorporated lessons learned during the 2004 season and feedback received from other members; added information on the 2005 R-compound tire choices - 05.02.05
Old Jul 8, 2005 | 02:01 PM
UNC04SuzukaBlue's Avatar
Originally Posted by Driv300mph,Mar 2 2005, 05:39 PM
anyone know what the STOCK allignment is??
From the 2000-2004 Service Manual ...
* means degrees and ' means minutes. 60 minutes per degree.
+/- means "plus or minus".
Caster angle: 6*00' +/- 15'
Front camber: -0*30' +/- 10'
Rear camber: -1*30' +/- 10'
Front toe-in: 0 +/- 2 mm (0 +/- 0.08 inches)
Rear toe-in (pre-04): 6.0 +/- 2 mm (0.25 +/- 0.08 inches)
Rear toe-in (04+): 3.7 +/- 2 mm (0.14 +/- 0.08 inches)
Here's the same info without minutes (which are a pita to think about) and without millimeters (since nobody seems to talk about toe in millimeters).
Caster angle: 6 degrees
Front camber: -0.5 degrees
Rear camber: -1.5 degrees
Front toe: none
Rear toe-in (pre-04): 0.25 inches (i.e. 1/4)
Rear toe-in (04+): 0.14 inches (i.e. a bit more than 1/8)
Old Nov 8, 2005 | 11:20 AM
Orthonormal's Avatar
I think it's about time to add a link to the AP2 stock legal wheels thread.
Old Oct 24, 2006 | 01:52 PM
jasonw's Avatar
Can we try to get a list of good setups for BSP or SM?
Old Oct 24, 2006 | 08:32 PM
jasonw's Avatar
Here's another Q. Where is a good place to practice?
Old Jan 19, 2007 | 08:16 PM
JamesR's Avatar
Greg, Steve, et. al.
Just thought I'd check out the setup info. I just took delivery of a 2006 S2k since I lost my Boxster ride and haven't found a real home I just decided to go to the dark side with you guys. Hope I can learn to drive in less than a year. So maybe you guys will have another year to kick me around.
James Rogerson
Old Feb 7, 2007 | 09:12 PM
ourru's Avatar
Possible Classification
AS
BSP
SM2
EM
FP
not sure if its different for AP1 and AP2 though
Old Feb 8, 2007 | 03:25 AM
jguerdat's Avatar
Nope, no difference in classes between years.
Old Feb 10, 2007 | 07:33 PM
ourru's Avatar
this write-up was done in 2004, i was wondering if any new products have come out that might be worth consideration as far as sway bars, struts, wheels, etc?
Old Feb 11, 2007 | 10:55 AM
Updated to FAQ to v1.3 to stop all the bellyaching. There really haven't been a lot of new developments in the past two years -- the main things have been the advent of the Hoosier A6, and the increasing trend towards running equally-sized tires at all four corners.
And James, I moved the other way -- I'm now driving a Boxster S.
