Safety Restraints for Your Head Are a Priority Precaution
Old Jan 8, 2018 | 06:04 PM
Chibo's Avatar
Yeah.... that's the tip of the iceberg for them...
Old Jan 12, 2018 | 12:56 PM
NoDelta's Avatar
Originally Posted by imstimpy
This is a blatant and misleading advertisement for the Schroth system. Nowhere in either article does it mention the requirements to safely use HNR. Please do not follow this advertisement blindly. Yes, HNR is very beneficial, but only if used as part of a system of safety upgrades.
Safety is not a one size fits all and, for cars like the S2000, adding incomplete safety systems may result in a more dangerous car, rather than a safer one.
Do you know of a good source of entry-level info on the topic?
I just installed my first rollbar and intend to upgrade to seats and harnesses.
When choosing my seats, do I need to be thinking about HNR?
What sorts of options are out there, aside from manufacturer?
Old Jan 12, 2018 | 02:35 PM
Chibo's Avatar
Schroth has good documentation. https://www.schrothracing.com/instructions
I strongly suggest you get a containment seat. HANS is for F-R collisions, a containment seat will keep your head in place in an offset/diagonal/sideways impact. There are other HNR systems that will help in these types of impacts.
These cars are tight inside, so it's not real easy to have a dual purpose car once you make the dive into safety, in comparison to something like an E46.
Old Jan 13, 2018 | 03:29 PM
imstimpy's Avatar
Traqhq has one of the better threads I came across when I was in need of some understanding.
Schroth also has some great material, as does most of the harness manufacturers. HANS also has some good documentation.
Everything is tied together as a system. A few examples:
  • Your rollbar should place the harness bar within ~200mm
  • Your rollbar should place your harness bar no lower than 20* from your shoulders
  • Your shoulder height is positioned by your seat and your seat rails
  • Your shoulders need to align with the passthrough holes for your harness.
  • If you have a harness you need a rollbar, if you need a harness you need a seat, if you have a harness you need a head and neck restraint.
Smu2000
Nov 4, 2001 09:13 PM
NJTom2000
Feb 21, 2001 03:56 PM
