Sakebomb Garage Wilwood Track-Day Brake System Review
#51
I have put a little over 1000 miles of track use on the setup and I haven't had any issues with the hardware itself. No leaks from the bleeders, leaks from the lines, or issues with the rotors. On Sunday, I ran 6 sessions and each session was around an hour (or however long it took me to run through a tank of gas) and I did not experience any brake fade or diminished braking at all. I don't run any brake ducting and I haven't bleed my brakes since installing the kit; I use Castrol SRF for what its worth.
My biggest gripe is the engagement of ABS; it is very easy to engage ABS. I run DTC30 front and rear and while pads contribute tremendously so the situation, I wonder if I have too much bias in the front now since went with the 41MM pistons not 36MM. Until I swap out the pads though, I can't can't fault the calipers. I need to measure how much pad I have left, but visually it looks like plenty.
I would still recommend buying this kit.
SakeBomb Garage (07-11-2017)
#52
Is this with the stock rear brakes or the SBG RX8 kit? If it's with RX8, that's odd as SBG implies that the two kits were designed to work together. Any chance you can tell which end is going into ABS first?
#53
__________________
SAKEBOMB GARAGE > Click here to contact Us
Check some of our most popular products for the S2000:
- Ohlins DFV Billet Lower Mount
- Rear BBK RX-8 Caliper Conversion
- Front BBK AP Competition
- Setrab Oil Cooler Kit
#54
We recommend the larger piston size for use with the rear kit (or if you are planning on adding the rear kit in the future). If you are not planning on running the rear kit we recommend the smaller piston size. We do NOT recommend the small front piston with the RX8 rear conversion kit due to the rear bias increase.
__________________
#55
The DTC30's are the issue... I would HIGHLY HIGHLY recommend moving to a Ferodo DS2500 or DS3000, they're our new favorite pad from a noise, rotor wear, and torque standpoint. Low dust, good initial bite but not too high... basically the perfect pads and they're quite affordable. They come in a 50mm height as well, where the Hawks only come in 43mm tall so you use more of the rotor.
#56
The rears aren't as important... but we are working with Ferodo to make custom RX8 rear pads for us now. In the mean time, we've been happy with Carbotech, Hawk HP+, etc for rear pads... cheap and quickly available.
__________________
#58
Nope, not compatible. The Wilwood discs are actually pretty poor as far as rings go. We make our own 325x32 directional curved vane disc, and have an optional 325x32 AP Racing Floating disc which is reverse compatible with this kit (upgrade cost is $500 for serious track enthusiasts).
__________________
#59
It's worth mentioning you can get a Stoptech ST40 kit for $1550 all day. It is also worth mentioning they are an OEM grade manufacturer and they custom size the pistons to maintain factory brake balance on the S2000 using the stock rear caliper. The quality of the Stoptech kit is top notch. I have used the Wilwood stuff on Corvettes in the past and they are ok and I have used RacingBrake on S2000s and it doesn't even compare to Stoptech.
#60
I have the SBG AP kit and love it. Seeing as this kit is a less expensive version I am sure it is worth every penny and would be my first choice in this price range. The calipers use the same pads which are giant 20mm thick pads, this alone would make me pick this over the ST kit
