Saner bar adjustment
Forgive me if the answer to the question should be obvious... But which set of mounting holes on the Saner bar represent the full stiff setting? The holes all the way at the end of the bar? Or the first set of holes?
Andrew - who just set the bar on the middle setting because he could not figure it out
The bar in the above pic is set on full stiff. The closer 'inward' you go on the bar, the stiffer the setting. The endlink will likely need to go on the other side of the tab on the lower control arm, though.
Since I can't see SC_Highlander's picture -- for the Saner and all conventional sway bars, the holes that result in the shortest lever arm (in other words, the holes closest to where the bar mounts to the chassis and pivots) are the stiffest. For S2000 bars, that means the holes closest to the front of the car.
Steve
Steve
