Saner swaybar out, stocker back in...?
I pulled my Saner front swaybar, and I was going to swap the stock swaybar back in. It was later afternoon, and I have poor lighting options, but I figured, meh, 2 hours should be plenty of time. So I yanked the Saner out in 30 minutes, no problems. But putting the stock bar back in gave me fits though. Nothing was lining up. I'd jack up a LCA and still couldn't get everything in place. Then, as it was getting dark and the 'skeeters were draining the blood from my body, I thought, "do I have this on upside-down?". The Saner bar goes over the tie rod (steering rod), but does the stock swaybar go under the tie rod? I can't remember from when I pulled it out a year ago. It doesn't look like the brake line will work at all if the stock bar comes over the tie rod. Needless to say, I ran out of daylight and didn't have the time to flip the stock bar around and see if that's correct. Any advice? Pictures are helpfull too as I can't remember how the stock end links are supposed to be oriented. Thanks a ton!
-Mike
-Mike
I don't remember doing anything special with the endlinks or alignment when I put my stock bar back on -- I just put it on the same way the Saner went on and it fit fine. Make sure you aren't trying to put the bar or endlinks on upside down or anything.
Steve
Steve
Originally Posted by payneinthe,Sep 22 2004, 08:26 PM
Maybe you attached the endlinks to the wrong side of the control arm.
I did get one side connected the other night, but the brake line would have had to run straight through the swaybar. I'm thoughouly confused.
jojipoji
Sep 27, 2012 03:54 AM
Bones Applesauce
Nov 17, 2008 01:43 PM
ssucsy
Jun 24, 2004 09:40 AM
