SCCA STU Build by Driving Ambition
Old Jan 19, 2012 | 07:49 AM
  #121
DrivingAmbition's Avatar
Update,
Parts are starting to come in for the project. The great Guys @ Performance Shock Inc (www.performanceshock.com) helped us out with a new set of Ohlins TTX shocks that PSI custom builds for the S2000. Rylan found a good pair of the billet upper control arms from another S2ki member. We are also working on our own new designed rear hubs, Rylan had broken a couple pair on his old race car. We are going to put this car together with just new OEM hubs, but are working on some new stronger ones before the Run Offs. The gearbox is in customs in LA and should clear on Friday, hopefully we will see it the first of next week. Cheers, Shad
Attached Thumbnails SCCA STU Build by Driving Ambition-dsc06654.jpg   SCCA STU Build by Driving Ambition-dsc06655.jpg   SCCA STU Build by Driving Ambition-dsc06656.jpg   SCCA STU Build by Driving Ambition-dsc06657.jpg   SCCA STU Build by Driving Ambition-dsc06658.jpg
Old Jan 19, 2012 | 11:53 AM
  #122
cracknut's Avatar
Good stuff.
I am finding the Ohlins don't need as much spring as the Motons did.
Are you shooting for the Thill Nationals second weekend of March?
Old Jan 19, 2012 | 01:44 PM
  #123
Antonov's Avatar
winning!
Old Jan 23, 2012 | 03:17 PM
  #124
Originally Posted by cracknut
Good stuff.
That is the goal.................We are starting off with the same rates you are running 900 and 800.
Old Jan 23, 2012 | 04:39 PM
  #125
krazik's Avatar
Administrator
:need more pictures:
Old Jan 24, 2012 | 10:13 PM
  #126
Update,
The trans is still in customs in LA waiting to be released, hopefully soon. Got the shock tops and springs from Ground Control around the corner. I will have to machine some spacers for everything to work properly. Got the trunk hinges drilled out and the trunk fit. Got all of the uprights built with new bearings, hubs and ARP wheel studs. Wheels showed up and all the suspension arms got sent off to Asura for mono-ball install. Cheers, Shad
Attached Thumbnails SCCA STU Build by Driving Ambition-dsc06665.jpg   SCCA STU Build by Driving Ambition-dsc06667.jpg   SCCA STU Build by Driving Ambition-dsc06668.jpg   SCCA STU Build by Driving Ambition-dsc06671.jpg   SCCA STU Build by Driving Ambition-dsc06672.jpg
SCCA STU Build by Driving Ambition-dsc06673.jpg   SCCA STU Build by Driving Ambition-dsc06674.jpg   SCCA STU Build by Driving Ambition-dsc06676.jpg
Old Jan 25, 2012 | 04:09 AM
  #127
dan_uk's Avatar
that looks awesome! are you doing the lexan for hardtop glass? thats another easy 10/15lbs over stock I think
Old Jan 25, 2012 | 05:26 AM
  #128
Mrsideways's Avatar
8lbs wasn't it?
  #129
Mrsideways's Avatar
8lbs wasn't it?
Old Jan 25, 2012 | 05:56 AM
  #130
krazik's Avatar
Administrator
yes we are doing it
