Sears Point blew engine.
Old Sep 3, 2007 | 11:13 AM
mikegarrison's Avatar
Originally Posted by rlaifatt,Sep 3 2007, 11:59 AM
Oil temp and pressure are what really matter though, right?
Both oil and water matter. But I would have thought the oil temp would have spiked once the oil became the only place for the engine to dump heat into.
Maybe he didn't have an oil temp sensor?
Ludedude's Avatar
Administrator
Originally Posted by mikegarrison,Sep 3 2007, 11:54 AM
Yeah, with no water to measure, the thermocouple (which what I assume the sensor is) would just be measuring air temperature. The air is not an efficient heat transfer fluid.
What you would need in this case is a water level sensor to go along with the water temp sensor.
Yeah that makes sense once I thought about it Mike. Hadn't factored in the "air is a crappy temperature conductor" bit.
Old Sep 3, 2007 | 11:25 AM
crash's Avatar
I did not have a oil pressure or temp sensor.
I will before I run again.
Old Sep 3, 2007 | 11:38 AM
I don't either. Now that the car is essentially track-only (even though I'm not racing it and the engine is completely stock), it seems like I should get around to doing that too.
Old Sep 3, 2007 | 11:46 AM
Asura's Avatar
James let me know if I can assist you with anything. I head back to SoCal tomorrow AM.
Old Sep 3, 2007 | 02:32 PM
tinkfist's Avatar
Sorry to hear crashtest No one noticed 2 gallons of fluid coming out of your car?
Old Sep 3, 2007 | 03:04 PM
krazik's Avatar
Administrator
yeah sucks for james. Remember too after qual you were gushing water. I knew it wasn't just a hose clamp
Old Sep 3, 2007 | 07:41 PM
s2ktarga's Avatar
Sucks dude, sorry to hear
Old Sep 3, 2007 | 08:40 PM
crash's Avatar
I just found where the water was coming from.
there is a coolant pipe on block where the lower hose connects to and then a pipe coming off that for I think the heater hose.
I had a rubber plug on there with a hose clamp and the plug split where the clamp is.
Shitty part is the day before like ry said I was leaking from a rubber plug.
I went around and tightened all of them thinking it was a good idea.
I guess I had tightened that one too much and it cut it.
lame is the bottom line
and tinkfist the answer is no. I even pulled off and asked the fire guys at turn 7 if I was leaking and they said no.
Old Sep 3, 2007 | 11:07 PM
krazik's Avatar
Administrator
yeah you weren't leaking you were empty
did you get the head off the motor tonight?
