Seat rail/mount setup for Sparco Evo2 w/roll bar
Old 10-20-2016, 04:00 PM
  #21
usafstud's Avatar
Originally Posted by gtracer
I've managed to fit my Evo 2 Plus (now called the Evo 2) with the PCI Adjustable mounts. PCI Website Link I had to trim the seat quite a bit for it to clear the transmission tunnel. If not, the seat was offset to the left and felt like I was driving a '63 cobra.
Would pci adjustable/evo2 help with trying to grt lower than stock seat heat?
Old 10-29-2016, 12:45 PM
  #22
gtracer's Avatar
Yes very much so.. That was the main reason for the purchase.. I could not drive the car with the stock seat and wheel.
Although the PCI mount is adjustable, once you tighten all the bolts, its a "fixed" mount. It does not have sliders but thats the trade off to be as low as possible
Old 10-29-2016, 01:45 PM
  #23
sirbikealot7's Avatar
How far is the base of the seat from the carpet with the pci mount? Unless its touching or damn close, its not nearly as low as possible. If it is then that looks like a great off the shelf solution to the problem. If my seat sat 1/2" off the carpet it wouldn't be low enough for me to clear with a helmet. But 6'3" problems. I should have learned my lesson coming from a Miata
Old 10-30-2016, 08:20 AM
  #24
robrob's Avatar
I had an Evo II floor mounted with no carpet and the first time I sat in the new seat I felt like a midget and I"m 6' 2". It can get you really low.
Old 12-01-2016, 10:47 AM
  #25
SlowTeg's Avatar
FWIW I finally test fitted this seat (brand new Evo 2) in the car and as expected it's a very snug fit. I'm using bc rails and am the 2nd from the bottom on the mounting holes for the front and the back. I'd say the seat sits you ~1" lower than my '06 oem seat (this is just a guesstimate). The seat has a wide base as people have noted so you can't use the very lowest mounting hole on the bc rails (as the base of the seat won't clear the rails at this point), but for me at 5'9", that extra 3/4" or so won't make a big difference. I used some large washers and flipped the brackets around 90 degrees on either the front or the rear (can't remember which) since the base of the seat is V shaped and gets wider as it comes forward.
Regarding fitment in the car, if you want it to slide w/ the sliders, you will need to trim the seat at the lower part by the tranny tunnel. It touches. You might need to trim on the driver's side lower as well by the frame rail/door where it barely touches, and the wing on the door panel just lightly touches as well. I'm debating switching to a pole position at this point because the EVO2 is a little snugger on my hips than I would like. We'll see. I haven't cut the seat yet, but it'd be quite easy to do the trimming with a dremel and put the cover back on. One other note, the bottom cushion is very flat in the butt region and very high under your leg which puts you at slight recline relative to the seat. For this reason I found using a higher mounting point on the front made me sit at too much of a recline. Just an FYI. Removing the seat pad you will sit leaning forward and it's quite uncomfortable. I'd definitely recommend against running without the seat pad. I'll try to get some pictures up soon.
I'm not sure what's up with this POS site but I can't seem to copy links to add images anymore.. FU VBulletin pos..
The following 2 users liked this post by SlowTeg:
S2000_916 (12-01-2016), Xene (12-03-2016)
Old 12-02-2016, 03:57 PM
  #26
S2000_916's Avatar
waiting for pics!
Old 12-02-2016, 05:42 PM
  #27
SlowTeg's Avatar
Originally Posted by S2000_916
waiting for pics!
Can you post links to pictures without them being direct links to the files? Microsoft onedrive and Google Photos doesn't provide you with direct file access but a url. The old s2k supported it but it doesn't seem VBullcrapola supports it. Hopefully I'm wrong and I just don't know how the new forum works..
Old 12-03-2016, 02:11 AM
  #28
djsilverjohnson's Avatar
Here are the instructions for the new picture uploader, but don't know if it works.
S2KI Honda S2000 Forums - Announcements in Forum : S2000 Racing and Competition
S2000_916 (12-03-2016)
Old 12-05-2016, 05:36 AM
  #29
SlowTeg's Avatar
Thumbs down
Dj,
Thanks, but the photo uploader is junk. Seems like a javascript bug because as soon as I start typing it resets the text to the default message. Using firefox here. I mentioned it to IB staff, so maybe it'll get fixed. I guess I could try chrome or IE, but I'm not hopeful, it'd be much better, not to mention it should work for firefox..
I gotta hand it to the admins. What a great way to kill a site with already declining viewership..
Old 12-05-2016, 05:43 AM
  #30
SlowTeg's Avatar
I'll just post the links here, apologies that they're not embedded, but you can blame s2ki.
https://vkn1lq-dm2305.files.1drv.com...&cropmode=none
https://van1lq-dm2305.files.1drv.com...&cropmode=none
https://u6n1lq-dm2305.files.1drv.com...&cropmode=none
https://uqn1lq-dm2305.files.1drv.com...&cropmode=none
S2000_916 (12-06-2016)
Quick Reply: Seat rail/mount setup for Sparco Evo2 w/roll bar
