Sequential installation in S2000
Old Feb 22, 2010 | 03:11 PM
  #21
MontinolaRacing's Avatar
how much power can that gearbox take?
thanks!
Old Feb 22, 2010 | 03:27 PM
  #22
Antonov's Avatar
Originally Posted by Andrew Wojteczko,Feb 22 2010, 03:24 PM
Yep
back about 1.25" down about 1" and rotated 3 degrees
trying to get more rearward weight distribution and reduced yaw inertia to help power down and improve response in the transitions.
Andrew
Nice! New shifter location looks much better too. Did you run into any interference issues with the firewall?
-Dino
Old Feb 22, 2010 | 04:28 PM
  #23
Andrew Wojteczko's Avatar
I've removed the harness that went behind the valve cover And will re route that in the Motorsports harness I'm building. Otherwise everything cleared the firewall. The stiffer mounts will be needed I'm sure to prevent excessive movement causing contact with the firewall. The smaller bellhousing shape made for lots of room and it even fits dropping in as an assembly from the top Which is a big plus for trackside engine swap which hopefully won't be necessary.
The 60g is rated at 450hp but I understand this is conservative. While I'm not sure it would stand up to the shock loading for drag/autox use I'm confident it will hold the 550whp we have planned. Time will tell.
Old Feb 22, 2010 | 07:00 PM
  #24
Antonov's Avatar
^^^ Nice. I'm pretty sure that rating is more in line with abuse experienced in w2w, as opposed to ta.
-Dino
Andrew Wojteczko
Sep 5, 2012 12:29 AM
Slambo
Aug 18, 2008 09:15 PM
zener_diode
Feb 12, 2006 04:23 PM
