Shock stiffness
Old Aug 3, 2006 | 08:17 PM
gomarlins3's Avatar
Default Shock stiffness
What would be the effect to having a softer shock setting in the front than the rear? Would the car rotate more or less? Would it be more likely to under/oversteer?
Old Aug 3, 2006 | 09:02 PM
blackey's Avatar
http://rogerkrausracing.com/overundr.html
It would oversteer.
Old Aug 4, 2006 | 05:37 AM
Conedodger's Avatar
Soft front shocks will allow weight transfer to the front, making the rear lighter and more prone to sliding.
Old Aug 4, 2006 | 06:15 AM
gomarlins3's Avatar
So if I soften the rears and leave the fronts stiff, will that help to keep the rear planted around cones and sweepers?
Old Aug 4, 2006 | 08:08 AM
Suspension's Avatar
If you soften the rears and leave the front stiff it will probably keep it more planted around cones and other transient maneuvers but the car might not rotate as well as it will have "transient" understeer.
Dampers shouldn't have much affect on steady state cornering such as sweepers, only in transients as you enter a turn or exit it.
Old Aug 7, 2006 | 03:21 PM
gomarlins3's Avatar
Thank you.
austincrx
Apr 21, 2017 06:12 AM
liquid_helix136
Oct 21, 2015 04:35 AM
spa-zz
Dec 11, 2006 04:12 AM
s2kVABeachCruiser
Oct 25, 2005 03:06 PM
vmb
Jul 15, 2003 01:01 AM
