Shocks for STR
As has been described already, I'm not sure there is much terminal speed to be had at the extreme end of the performance envelope with one shock over another, its just much easier to get to the upper 10% of that maximum performance and keep the car there with good stuff. I didn't notice a significant change in my best run time comparisons when I went from OTS Konis to Penskes on my BS setup, but I could recreate that "hero run" significantly more consistently than I could before.
I know KW was brought up, but maybe look into KW Clubsports. I have heard good things about them. I ran a revalved version of the KWV3s on my STI in 2008-2009. I used to race my S2000 in stock class before that and did very well on stock shocks. I switched to Koni yellows and never did as well on those. Might have been other factors involved but like everyone is saying, high-end shocks just make the car easier to drive but not necessarily any faster.
This car will be used as a (short distance) daily driver too - does that change my selection criteria at all?
Also, how often do you have to rebuild these shocks? Does the rebuild frequency or cost change between revalved koni yellows, other $2000-ish shocks, and higher end ones like Motons or Penskes?
Originally Posted by IntegraR0064,Jun 24 2010, 11:17 AM
What is the difference between the clubsport and the v3 anyway? It sounded like you'd have to revalve the v3 for 600-800 lb springs - is this the case with the clubsport as well?
High end shocks generally have better valving and fluid movement characteristics that keep your tire in contact with the road more.
How much more is up for debate, not if they are better.
