Shocks upgrade?
Old Jun 30, 2005 | 10:19 AM
124Spider's Avatar
Default Shocks upgrade?
I was at a track weekend last weekend, and I took advantage of the opportunity to ride along during a session with a very good driver in a race-prepared CRX. Ignoring his obviously superior skill, his car didn't lean in the fast corners like mine seems to do. I liked that.
Are there shocks/springs which will give less lean with an '04 S2000 on the track, and still be legal for stock class autocross?
If so, can someone make recommendations, and give me some idea of price and difficulty of installation?
Thanks.
Old Jun 30, 2005 | 10:25 AM
Conedodger's Avatar
Springs can't be changed in stock class. Shocks can. Konis can be had for about $600, but I hear it is debateable how much improvement they are over stock. After that, you are looking at Penskes, Motons, Ohlins, etc. Too pricey for me at $3k+
Old Jun 30, 2005 | 04:40 PM
Gruppe-S's Avatar
Banned
Or you can look into Zeal!
Tom
Old Jun 30, 2005 | 06:49 PM
shaggy's Avatar
The Zeal units might be a good damper but...
Unless Zeal offers fully customer serviceable double adjustable dampers that retain the stock spring perch location, they're not the right tool for stock class.
I can't emphasize enough how double adjustable shocks that the owner can revalve easily are the key to a championship S2000. Only one car on "off the shelf" shocks finished in the top 10 in B Stock last year... and it was on stock shocks. All of the top 5 BS drivers were on Moton or Penske shocks that are very custom builds.
Andy H.
Old Jun 30, 2005 | 06:59 PM
124Spider's Avatar
Ok, so it seems that, if I go to the trouble and expense of swapping out my shocks, I need to go with double adjustable shocks that the owner can revalve easily, such as the Moton or Penske shocks. Does one have to have these custom made and/or custom installed? Does that add to the $3k price tag? Are these usable on a car that is also my daily driver? Are these helpful, harmful or neutral for tracking the car?
It also seems that I must stay with stock springs, if I want to stay in stock class in autox.
Thanks.
Old Jun 30, 2005 | 07:16 PM
mikegarrison's Avatar
Does a double or triple adjustible shock really have to be custom-valved? I guess maybe I'm not understanding either the "adjustible" part or the "custom-valved" part.
Old Jun 30, 2005 | 07:29 PM
Ludedude's Avatar
Administrator
Thanks.
The cheapest "competition" type double-adjustable shocks are the Moton Clubsports. They start at $3695 without springs (You can't use those for stock class anyway) or pillowball mounts (not good for stock class either). The only option you might consider are the quick disconnects for the remote reservoirs.
Old Jun 30, 2005 | 07:31 PM
Ludedude's Avatar
Administrator
Adjustable has to do with the range and scope of adjustments (compression, rebound etc.).
Custom valving has to do with matching the shock valving to the spring rates so that the car isn't under or over damped.
Old Jun 30, 2005 | 07:36 PM
jlucas's Avatar
Koni 2812s
I've been very happy with mine and they are used (and valved to) stock springs.
Old Jun 30, 2005 | 07:39 PM
Ludedude's Avatar
Administrator
Forgot about those. Koni makes some nice stuff too.
