Slow Motion video of the diff while launching
I've wondered for years what was going on under my car in a launch. A fellow racer was kind enough to lend me his GoPro3 to get these shots. These are played back at 1/8th speed.
http://www.youtube.com/watch?v=piGLtGXEa8Q (no sound)
It's interesting to see how much the diff mount moves, and you can see it bouncing around a bit as the car builds speed.
^^^ was thinking the same thing. The OEM mounts are rubber and fluid, putting solid mounts there would transmit the rotational shock the axles to the diff itself (pinion gear specifically). The center bolt moves just up and down from Josh's video, suggesting that it's the axle stub shock that is creating the movement (and not vibration or G-forces from the physical chassis moving when driving).
The first shot where you can see the front diff mount area and drive shaft is amazing. Everything twisting and bending in every direction... I now feel bad launching on slicks. Ill post up how much my rear diff mounts move when i launch, its incredible
