Sonoma Raceway
Old Apr 28, 2013 | 10:15 AM
RSXLNT's Avatar
Default Sonoma Raceway
I'm thinking about making the pilgrimage to Sonoma Raceway. I've always wanted to run that track, but they have a sound limit of 103 db.
My S2K has stock exhaust but I do run a K&N FIPK air intake. Has anyone run Sonoma Raceway with this and does it meet the sound restrictions?
Thanks!
Old Apr 28, 2013 | 10:29 AM
macr88's Avatar
When I was there people were running intakes and exhausts, 103 is pretty loud.
Old Apr 28, 2013 | 01:07 PM
thomsbrain's Avatar
I have K&N intake, Comptech header, and stock exhaust. Not even close to the 103 db limit at Sonoma. Even with a titanium single exhaust you wouldn't have a problem.
Old Apr 28, 2013 | 07:36 PM
ddess's Avatar
Probably an exaggeration. I'm thinking of pulling my Berk 3" for Sonoma because I'd doubt it will pass the 106 max.
Has anyone ran there with a single and TP and passed?
Old Apr 28, 2013 | 07:57 PM
MMisencik157's Avatar
You're fine... I used to run the berk 3" headerback with test pipe and have never had a problem passing the 103db limit
Old Apr 28, 2013 | 08:40 PM
ddess's Avatar
I'm shocked. I've emailed around and can't get an answer how loud the Berk is. I thought it was a sure fail.
I appreciate the info
Old Apr 28, 2013 | 09:02 PM
No problem, just thought I could save you the work of swapping it for that day
Not that its relevant to you, but I was also out at Sonoma with the EVS 70-SSP w/ 70mm test pipe and passed just fine with that setup too. Im not sure where they record the sound at Sonoma but I think its far enough away to be fine with most exhausts.
Old Apr 28, 2013 | 09:11 PM
shadow36's Avatar
same here. I have the 3 inch berk header back and the KN intake and had no problem.
Old Apr 29, 2013 | 06:01 AM
pmptx's Avatar
FIPK with stock exhaust at about 50' WOT was about 93dB at one of our local autox.
So no way a TP will run you up over 103
klapamos
Dec 13, 2016 02:55 AM
mchi5
Oct 18, 2016 10:20 AM
addison.lewis1
Oct 27, 2012 11:06 AM
Hobbs5313
Oct 1, 2007 09:17 AM
Rev_2_8k
Oct 23, 2006 10:34 PM
