Spacers & extended studs
Old Sep 2, 2012 | 08:38 AM
MB's Avatar
MB
Member
Default Spacers & extended studs
I might be fitting Spoon calipers under my CE28s (+50)
If I go for a 10-12mm hubcentric spacer with extended nuts, is there any mechanical downside, other than arch issues?
Can't think of one. Car is purely used for racing.
Thoughts appreciated.
Old Sep 3, 2012 | 07:32 AM
CKit's Avatar
Extended nuts? Or extended studs...
Old Sep 3, 2012 | 07:35 AM
MB's Avatar
MB
Member
Oops. Studs I meant!
Old Sep 3, 2012 | 12:56 PM
slightly2ned's Avatar
Just for reference, I needed at 13mm to be safe on 17x7.5 +50 CE28s.
Old Sep 3, 2012 | 01:27 PM
MB's Avatar
MB
Member
Ok thanks. Would I get away with 12?
Did you have any arch issues? I have near 3 deg camber on the front.
Thanks
Old Sep 4, 2012 | 04:56 AM
CKit's Avatar
When you say "arch," do you mean inside the fender well?
What width are your wheels and what width tire?
Old Sep 4, 2012 | 05:01 AM
MB's Avatar
MB
Member
Yep fenders. Arches is what we call them in the Uk (wheel arches)
I don't care about the liners, more that they will rub on the 'fender'
I have 17x7.5 with 235 / 45 A048s. Lowered on Nitrons (see my avatar)
Thanks!
Old Sep 4, 2012 | 07:17 AM
99SH's Avatar
I run a 17x10 wheel all around with 15mm spacers in the front and 20mm in the rear using extended studs.
Many track guys run spacers (not just s2k). As long as it's not the stud & spacer config built in to one unit, you'll be fine.
Old Sep 4, 2012 | 02:35 PM
mcopley's Avatar
Why is this? Do those units have some known issues? I'm thinking of running this Project Kics spacer on my new Toyota 86 GT (Scion FR-S). Will that be a problem?
Old Sep 4, 2012 | 04:33 PM
99SH's Avatar
I'm personally uncomfortable running those. You never know whether the internal lugnut has loosened, unless you take the wheel off every-time. Also unsure on the quality of metals used on that stubby stud.
You're safer off using a quality ARP extended stud, without dealing with 'two' sets of lug nuts; one behind the wheel and one in front.
