splitter mounting
Old Mar 6, 2017 | 01:59 PM
  #31
s2000ellier's Avatar
mounting to plastic is common but i wouldn't recommend it
Old Mar 7, 2017 | 04:43 PM
  #32
#BigSplitterProblems
Old Mar 7, 2017 | 05:43 PM
  #33
Singh_snisen's Avatar
U can't do that with carbon.
Old Mar 7, 2017 | 06:58 PM
  #34
sirbikealot7's Avatar
I used the 10" version of the longacre turnbuckle and mounted them to my bumper beam. 1/2" birch from Home depot.
Old Mar 15, 2017 | 08:17 AM
  #35
thomsbrain's Avatar
Anyone have any idea how long material needs to be to reach an air dam around the front bumper? I was thinking about stopping by a metal supply shop today if I have time.
Old Mar 15, 2017 | 08:25 AM
  #36
No.Division's Avatar
About 8 ft. I got a 10Ft roll of plastic to make my airdam setup.
Old Mar 23, 2017 | 01:09 PM
  #37
rioyellows2k's Avatar
I was inspired by the Speed Academy mounting. 4x 3/8" T6 Aluminum bars going to the frame rails down to 1/4" T6 Angle that's mounted to the splitter. 3/8" bars coming off the lower welded headlight support brackets down to 1/4" angles. Made a few extra 45 degree braces that went to the frame rails. Rear of my splitter goes back to the subframe stopping 3/4" in front of the oil pan. I put two rivet nuts in two drain holes in the subframe to fasten the rear of the splitter. I went with a 4" extension from the leading edge of my bumper/lip. I put a bulb type weather seal and it compresses to seal up the area when the bumper fasteners go in. I use Turnbuckles that are part cables to allow the splitter to flex upward when it contacts the ground without breaking like a solid support would but it still is solid on downward force. It supports my weight standing or hanging from.
I went with polymetal sign material. It's a solid thermoplastic sandwiched in between two sheets of aluminum. I paid $80 for a 4'x8' x 7mm panel of it. I was originally going to get dibond in 4mm thickness but 7mm seemed more robust. It is, but it may be heavier than necessary. It's reasonable once you cut away everything you don't use but 4mm dibond would have probably been ok. I didn't use alumalite since the plastic core is corrugated.
Old Mar 23, 2017 | 03:34 PM
  #38
that looks awesome
Old Mar 23, 2017 | 05:39 PM
  #39
RussianHammer's Avatar
Top Answer: 1
@rioyellows2k
Does your Polymetal splitter have any flex or does it wobble around. Or is it a solid panel due to the aluminum sheets?
Old Mar 24, 2017 | 03:45 PM
  #40
Kiwiflavored's Avatar
Also where did you purchase it for 80?
