spoon hardtop
I did quite a bit of searching/reading to sort of confirm, that for a dedicated track car spoon hardtop is the best option out there from an areo stand point. If that statement is not valid and there are better options out there, or better yet solid numbers to prove that, and I somehow missed it, please post.
Thank you.
Thank you.
yes, it is. However, from a points allocation basis, it is not. Most competitive organizations - NASA/SCCA and other TT/TA events tend to assign a lot more points to aftermarket hardtops, making them less useful when building your car to fit in a competitive class. If you even remotely think that your car might one day be a TTC, Honda Challenge Car, or competing in some sort of sanctioned body, I'd advise you to go OEM. Spoon top isn't worth the points assigned to it.
13) Add a non-OEM hardtop to a convertible that is not the identical shape and size of either the BTM or OEM option hardtop for that car model +5 (note: The top must not extend rearward of the front edge of the rear deck lid.)(“Fastback” tops and toneau covers are not permitted.)
Most of us just have accepted this:
1. use an OEM hardtop, or one you can PROVE is the same (burden of proof is on you)
2. take a major points hit for non OEM
3. Everything fastback or extended is strictly illegal
Time Trail:
-not legal in TTB-TTF, and TT3
-legal in TTU with no modification factor, and TT1/TT2 with modification factor (7.3.2.B.2)
2)Modification of the OEM roof line is permitted, but will be assessed via a Modification Factor in the “Adjusted Weight/Power Ratio”.
-legal only in SU with no modification factor, and ST1/ST2 with modification factor
...again, correct me if I'm wrong or misread something in the rules.
...and thanks everyone for pushing me to do more research on the topic.
it's a good read
... I'm on page 20 now
