Stainless brake line
Old Oct 4, 2008 | 07:36 PM
smirfs2k05's Avatar
Default Stainless brake line
I don't know if this is the right section for this but I was trying to do my stainless brake lines today and holy f'n blah blah curse word curse word I can't get the oe lines off. Where the brake lines meet the hardline it won't budge without stripping the fitting. I already stripped one on the drivers front and had to go buy a new hard line. Any tips or anything before I strip anymore haha this could get expensive.
Another thing I made myself a line wrench by cutting a slot in one of my cheapy craftsmen wrenches and even that would start to strip the fitting.
Old Oct 4, 2008 | 07:39 PM
Opposite_Lock's Avatar
You could try getting one of those swivel head line wrenches to get some snap in your torque delivery. Certain nuts and bolts need them to break them without stripping.
Old Oct 4, 2008 | 10:36 PM
Steve@PWJDM's Avatar
Former Sponsor
[QUOTE=smirfs2k05,Oct 4 2008, 07:36 PM] I don't know if this is the right section for this but I was trying to do my stainless brake lines today and holy f'n blah blah curse word curse word I can't get the oe lines off. Where the brake lines meet the hardline it won't budge without stripping the fitting. I already stripped one on the drivers front and had to go buy a new hard line. Any tips or anything before I strip anymore haha this could get expensive.
Old Oct 4, 2008 | 11:19 PM
smirfs2k05's Avatar
Originally Posted by Steve@PWJDM,Oct 4 2008, 10:36 PM
this should solve your problem...
get a hold of a Snap-On flare nut double end 6pt metric 10/12 wrench... these are by far the best line wrenches ever made. they are beefy and wont bend out like the craftsman ones. if you 've stripped them beyond the point of no return... try using a vise grip and lock them in tight...
these worked wonders for me and my brother when we were growing up wrenching for a living.
good luck.
Thats what I miss about working at a shop I had the snap on guy come every week ha now I have no clue how to trace one down. I stripped one and than I started on the next line and it seemed like it was going to strip so I called it a night.
Old Oct 4, 2008 | 11:25 PM
mikegarrison's Avatar
1) There is no reason to even be doing this. The OEM brake hoses are just fine.
2) What exactly are you doing? What do you mean "stripping the fitting"? Are you rounding off the corners? If so, just get a better flare nut wrench (as in, one that is not a dremel tool lashup jobbie).
Old Oct 5, 2008 | 02:37 AM
rob.ok's Avatar
I just this exact sequence of things...and I was the one that tightend the nut last time
Interested in hearing a better solution.
Old Oct 5, 2008 | 05:03 AM
U9aXy6Dn's Avatar
you want to lace anything with wd-40 before starting down there. The whole wheel arch area of the car needs to be washed and protected/coated(with copper grease etc) regularly otherwise it'll simply corrode to hell.
Old Oct 5, 2008 | 11:16 AM
Voodoo_S2K's Avatar
Try straying some PB Blaster or similiar penetrating oil first, and use the proper flared wrench.
Old Oct 5, 2008 | 01:56 PM
smirfs2k05's Avatar
Bought a new wrench today and letting the bolts soak.
the cut off wheel custom crapsmen wrench was just a quick fix but it didn't help or work
Old Oct 5, 2008 | 03:49 PM
smirfs2k05's Avatar
kicking myself in the ass.. I should've just bought a set of wrenches to begin with as soon as I put it on there it broke it free.
Chablonski
Mar 17, 2010 10:22 AM
CKit
Nov 14, 2009 09:31 AM
CLPark
Tampa
34
May 25, 2009 08:13 AM
puffman20
Oct 30, 2008 07:17 AM
