Which steel lug nuts to buy and where?
Are there particular steel lug nuts that everyone uses for the track? If so, which ones and where can I get some? Closed or open end is fine.
I would run aluminum lugs (and probably get the 949 lugs), but read about how steel lugs are just more durable and worth the extra weight.
Thanks
Thanks
These look similar to what came with my tire rack wheels ad they work fine.
http://www.proimporttuners.com/parts...-lug-nuts.html
Whatever lug nuts you decide to use, make certain they have the correct seat for your application. OEM Honda wheels use ball or spherical seats, whereas most aftermarket wheels use a tapered of conical seat. You risk losing the wheel if the wrong seat type is used.
