steering lock removal
Old May 8, 2007 | 11:24 AM
9kI4's Avatar
Default steering lock removal
This is what causes the steering wheel to lock when the ignition is switched off and the wheels are turned. Any help? I've tried the search function and can't come up with anything.
Old May 8, 2007 | 11:34 AM
krazik's Avatar
Administrator
The steering lock causes it. It puts a pin into the steering column when you turn the key to off.
There are threads about it. You can pull the steering column and block the pin w/ some tape or remove the key and lock totally and replace it w/ a switch.
I assume this is for a race car?
Old May 8, 2007 | 12:11 PM
9kI4's Avatar
Yes it is. What do most people do about this issue, just remove it and replace it with a toggle switch? Sorry, but I couldn't find the threads.
Old May 8, 2007 | 12:22 PM
Stratocaster's Avatar
Me, I will be removing it all together and installing a master cut off in it's place.
Old May 8, 2007 | 12:35 PM
rlaifatt's Avatar
Much easier (and safer I think) to just drill out the "button" on the bottom of the lock mechanism, and the spring falls out. This way you don't have to remove the steering column. I think I used a 3/8" bit, but not sure; just use one that is the approx. diameter of the button, which supports the bottom end of the spring.
Old May 8, 2007 | 02:13 PM
crash's Avatar
I just took a hammer and screwdriver to the bottom of it and beat the crap out of it untill the brass looking cap came off then the guts fell out.
Old May 8, 2007 | 04:44 PM
Actually in my case, it is a part already removed from my car. My car have NOTHING in it when I bought it. I have to buy everything for it. That is wires and all.
Old May 8, 2007 | 04:57 PM
krazik's Avatar
Administrator
Then in your case I recomend http://www.woodwardsteering.com/
robrob
May 31, 2016 02:53 PM
Kremlin
Nov 6, 2007 03:54 PM
scrawny
Oct 13, 2004 01:07 AM
sickestS2k00
Jan 13, 2004 08:34 PM
SNAPPER
Sep 28, 2002 07:13 AM
