Stock Alignment Capability?
Old Oct 24, 2008 | 12:44 AM
c32b's Avatar
Originally Posted by sirbunz,Oct 23 2008, 06:24 PM
Most stock legal S2000s with healthy bushings and no bends in the arms can't get -2. I would guess -1.7 is average out of the drivers front and -2 out of the passenger front. After some potholes, railroad tracks, curbs, etc. you can get as much as you want! lol My '05 got about -1.5/-1.8 and the CR got -1.7/-2.1 when they were new. After the '05 got to about 20k miles and 3 years old, the suspension would flex more when I loosened everything up. As a result I could force over -2 degrees before tightening everything back up. The CR is about the same after 4k miles and 6 months.
Sounds like you either have a very healthy suspension or the car has had something bent. A good custom alignment guy can get to the root of this for you. Good luck.
-Marc
i have:
Camber 2.0 F , 2.5 R
total front toe 0
total rear toe 34 min
castor 5'15 (funny that i could only get this max when stock was 6)
Old Dec 18, 2008 | 03:50 AM
scareyourpassenger's Avatar
Mine is lowered but they couldn't get more than 2.1 camber in the rear on mine or more than 2.0 camber up front..
Old Dec 18, 2008 | 12:49 PM
dan_uk's Avatar
max my 03 has read 1.8 front with 5.5degrees caster and 2.2 at the rear
thats was with me sitting in the car too
Old Dec 18, 2008 | 01:20 PM
3r1k's Avatar
More camber = Less caster but I could get -2 with 6 degrees caster though..
Old Dec 18, 2008 | 08:22 PM
krshultz's Avatar
My car is a 2004 with 45K miles on it. It'll get the following:
Front camber: 1.9L, 2.0R
Caster: 5.9L, 5.5R, so we set them both to 5.5
Rear camber: as much as 2.9L, 3.0R. I, personally, run 2.0 in the rear.
Old Dec 18, 2008 | 09:52 PM
ddess's Avatar
Originally Posted by Orpheus,Oct 23 2008, 07:15 AM
last alignment i got at West End (best in so. cal.)
Where is this place in So Cal? Most local shops by me stink.
Old Dec 19, 2008 | 03:15 PM
jei_s2k's Avatar
My 2006, I tried finding what max camber was on stock wheels and tires and got:
-2.7 camber front
-3.7 camber rear
+6 caster
with +45 17"x9" and 255's all around my current settings are:
FRONT
-2.8 camber
+6.6 caster
0 toe
REAR
-3.0 camber
1/4" total toe in
Old Dec 19, 2008 | 09:42 PM
nsxtasi's Avatar
Keep in mind your caster will affect the amount of camber you can get. If you told your alignment guy to get max caster before he do the camber, you'll see very little camber. I was able to get 1.7 in the front and 2.8 in the rear.
Old Dec 20, 2008 | 01:58 PM
124Spider's Avatar
I set camber at -1.75 front, the maxed out caster. I have -2.5 rear camber. All stock relevant suspension parts.
Old Dec 21, 2008 | 01:54 AM
jei_s2k's Avatar
[QUOTE=nsxtasi,Dec 19 2008, 10:42 PM]Keep in mind your caster will affect the amount of camber you can get.
