STR Autocross FAQ Review
Old Feb 22, 2010 | 10:44 AM
Random1's Avatar
Default STR Autocross FAQ Review
Here is a draft outline (ver 1.00 alpha) of the SCCA Autocross STR class FAQ for comment. Follow the link below.
At this point help fill in any gaps in the outline or priorities of mods. I will work on filling in the details in the mean time.
Thanks Steve (PedalFaster) as I used the stock class FAQ as a starting point.
Once this is done (good enough until we know more) a new sticky post can be created to store it.
DRAFT STR FAQ v1.00a
Old Feb 22, 2010 | 10:57 AM
marks_lude's Avatar
We tend to max out front camber in stock class. I imagine camber mods will be of interested to some.
maybe:
2.1.5.1 Camber, Caster, Toe
2.1.5.2 Camber Adding Mods
Old Feb 22, 2010 | 11:25 AM
daverx7's Avatar
Question.... Are you including the TC Kline DA's as a part of the Koni section?
Old Feb 22, 2010 | 11:54 AM
Random1's Avatar
Yeah, anything Koni, sport (yellows), sport DAs, 30s, 28s, what ever anyone will actually use.
Old Feb 25, 2010 | 01:30 PM
GEARHEAD's Avatar
2.1.4 - Does anyone care about spring brands? Seems like a discussion on rates front and rear and relevant anti-roll bars would be more beneficial - although highly driver dependent.
2.2.2 or 2.2.4 - Add light weight engine pulleys
Great start.
Old Mar 3, 2010 | 08:24 AM
User 121020's Avatar
2.1.3.6 - Other
Someone might be building a set of Bilstein PSS9s for STR
It'll be a while before they're ready...probably more like a long while.
Old Mar 3, 2010 | 10:22 AM
angryfist's Avatar
Originally Posted by nmrado,Mar 3 2010, 12:24 PM
2.1.3.6 - Other
why so long?
Old Mar 3, 2010 | 10:24 AM
josh7owens's Avatar
Great start.
So you can run light wieght pullies in str?
Old Mar 3, 2010 | 10:52 AM
[QUOTE=angryfist,Mar 3 2010, 01:22 PM] why so long?
Old Mar 3, 2010 | 06:18 PM
Random1's Avatar
Great start.
I do, and I am sure others do. Not all springs are created equal!
The intro section, 2.1.4, is intended to discuss rates, lengths.
Sway bares are covered in 2.2.1
sokkie
Apr 4, 2012 10:25 PM
00S2Ked
Jan 5, 2011 03:45 AM
dan_uk
Nov 9, 2008 05:22 AM
c32b
Feb 27, 2008 07:56 PM
Nickfromny
Jun 21, 2005 09:41 PM
