View Poll Results: What tires (primary) do you use?
Toyo R1R 245
0%
Toyo R1R 255
0%
Voters: 226. You may not vote on this poll
STR Prep - Wheels and Tires
Thinking of running 255/35/18 on a 18x8.5 rim +55 next year. You guys think the front will have clearance issue? I used to run a similar setup in my old car and really liked the feel of the lower profile tire.
Yeah your gonna have to at least roll the fronts to run that I am pretty sure. I ran a 18x8 +42 and it was danger to fenders zone at stock height. Maybe if you ran a lot of negative camber it might work.
You should actually be pretty good, especially since they're 8.5" width. I know people running +55 with 17x9 and it's not much different than the +63 that most people are running.
The car I codrove at nationals was pretty much that - 17x9 +55, 255/40/17 dunlops, I'd guess around 13" hub center to fender (might have been slightly higher but definitely not much), and 3 degrees camber or slightly lower. I think Nick Jackson was running the same thing, not sure what his ride height was at that time.
Would the 18's still be the same overall diameter?
