Street Tire size for AP1 wheels
Old Jan 25, 2006 | 09:06 AM
blanka98's Avatar
Default Street Tire size for AP1 wheels
Hey guys!
Since most of us here either have Auto X or Track events under our belt. I would like to get an opinion from you guys instead from other section of S2ki.
I am using my stock AP1 wheels for track and I also know that the stock SO2's have a 245 footprint.
I don't plan to run R compounds anytime in the near future, I like to keep my car stock from the streets to the track.
My question is:
I will plan to buy the Hankook RS2's 245/45/16 rears and 225/50/16's front. Many of us said having a wider front tires will cause the rear to oversteer more often, but if you have 205/55/16's this will help you understeer.
What are your experiences? MaxRev uses non staggered all around and just wanted to get more opinions from professional racers
Thanks!
Old Jan 25, 2006 | 10:38 AM
silversprint's Avatar
If you have a stock car stick with 205/245. The car is well balanced with this combo. It really doesn't understeer with 205s on the front.
Old Jan 25, 2006 | 05:57 PM
ken o's Avatar
Three of the local guys just got 225 F & 245 R Kooks with in one month of each other.
tpc0531 - all stock
p0pe - big front bar
ken orgeron - big front bar and aftermarket shocks
I have not had time for spirited driving on them. Tpc0531 did and Autocross on them.
I like the 225/245, but I have a diff setup.
I will post a link from the New Orleans forum asking for feedback to your thread.
Old Jan 26, 2006 | 06:31 AM
glagola1's Avatar
Basically, if your car is stock and you decide to go with the 225/245 combo you will have uncontrolable oversteer. It's real simple. The only way to dial in a 225/245 combo is to add a front bar that is bigger than stock by a good bit.
Old Jan 26, 2006 | 07:38 AM
p0pe's Avatar
Getting my tires installed on Saturday, along with an alignment. I'll report my results then.
Ken, what are alignment you running BTW?
right now at
-1.5 front -2.0 rear
0 front toe, max caster
1/4" toe in rear
Thinking about going with -1.75 front -2.25 rear camber, everything else the same. I feel like the car oversteers a bit too much and the rear wants to step out, especially in quick transitions.
Old Jan 26, 2006 | 09:41 AM
tenchi950's Avatar
I would stick with stock sizes. Those are optimum when everything is stock. I suggest getting the UK alignment as well. It will help the rear be more planted.
I also have Toyos in stock AP1 sizes with plenty tread if your interested.
Old Jan 29, 2006 | 10:40 AM
p0pe's Avatar
Got my R-S2's on yesterday and they feel great. Almost as much grip as the Azenis . The sidewalls are a little softer, but not by much. I'm running 225f/245r with a saner bar on full stiff.
Old Jan 29, 2006 | 01:36 PM
spa-zz's Avatar
I just installed a Gendron bar at full stiff and it's the first time I have ever experienced understeer in this car.
Still doesn't understeer as much as my stock E46 M3 did though!
I have OEM AP2 tires now. I may go to a 225 front to try to recover a bit of that grip.
Old Jan 29, 2006 | 01:38 PM
Kel's Avatar
Kel
Wait, how is it "uncontrollable"?
Old Jan 29, 2006 | 10:01 PM
cthree's Avatar
Administrator
There are 3 pedals where your feet go. The one on the right is the over-steer controller pedal
