Suspension setup for nonsteggered setup?
Old Oct 2, 2009 | 10:11 AM
  #91
WynnS123's Avatar
^^ I have the same setup (KW V3 / Saner bar / 255's all around) but I run my fsb on full soft. My car is more prone to oversteer.
I would stiffen the rear rebound if you want oversteer.
Old Oct 2, 2009 | 10:31 AM
  #92
scareyourpassenger's Avatar
I am looking to improve rear traction during exit as the inside wheel is lifting and losing traction.
I wouldn't mind taming the oversteer a bit as well.
Old Aug 18, 2010 | 07:06 AM
  #93
TubeDriver's Avatar
update on an old thread:
Ran an APR GTC-200 wing on risers and it made a TREMENDOUS difference on the track. Car is super tossable (like my old Miata track car). I am very happy with the settings but will be going from a 225/255 to a 255/255 setting this weekend so I expect some additional adjustment will be needed.
I will start by setting my CT swaybar on full stiff, and stiffening up front compression and rebound a bit.
Old Aug 18, 2010 | 07:34 AM
  #94
nissanfanatic's Avatar
I am going to be trying CR front springs/struts on the front of my MY2000 with non stagger 255/40s. I'll make sure and post my results in this thread.
Old Aug 18, 2010 | 07:39 AM
  #95
patinum's Avatar
FYI - my CR on non-staggered 255's feels good on both autox and track with my comptech bar on full stiff. My alignment hasn't been checked in over a year, but I did have max camber and caster and 0 toe front and rear.
Old Aug 18, 2010 | 09:04 AM
  #96
psychoazn's Avatar
For comparison purposes, my CR will always lose grip in the rear before the front. 255 non-staggered, max camber/caster in the front (no camber joint), -2.5 camber rear, 3/16 total toe in the rear.
biondoS2000
Mar 16, 2015 06:48 PM
trueblood
Jan 31, 2012 04:05 AM
VolkMan
Dec 5, 2009 02:09 AM
abmusser
Aug 18, 2009 05:55 AM
s2konroids
Oct 3, 2008 11:30 PM
