sway bar questions
Old Jun 8, 2007 | 04:38 PM
jeggy's Avatar
Default sway bar questions
http://cgi.ebay.com/ebaymotors/Honda-S2000...1QQcmdZViewItem
i been looking and waiting for one of the 3 (comptech,saner,grendon) front swaybars to pop up for sale for a while now and went on ebay last night to look for one when i came across a 30mm solid bar for like $200 buks.
the bar is 30mm solid. some of the other 3 are 1.25" (slightly smaller then 30mm) and hollow and stiffer then oem.
being slightly larger and solid, this ebay brand stabilizer should be stiffer then oem as well right?
what do you all think? should i try it? should i risk it? waste of my time?
*i just found a chart on their website for stiffness*
http://www.whiteline.com.au/docs/bulletins/010barup.pdf
i dont know the stock front swaybar size at the moment.
Old Jun 9, 2007 | 03:41 AM
Fongu's Avatar
MY00-MY01 FSB: diameter 28.2 mm, wall thickness 5mm
MY02+ FSB: diameter 26.5 mm, wall thickness 4.5mm
The chart you link is applicable to solid bars using the same material of the Whiteline bar. You can't really use it for hollow bars, like the OEM. I've seen 50% stiffer than stock (which I assume means MY00-01) quoted for the Whiteline. Here is a link to the thread with a compilation of FSB's.
https://www.s2ki.com/forums/index.php?showtopic=351694
It's really cheap, so no reason not to try it. It's going to be stiffer than stock. Whether or not it's right for you or your application who knows? You have to try and find out.
[/shameless plug on]
FYI I do have a Comptech adjustable FSB for sale. It 's a little more expensive than the Whiteline though
https://www.s2ki.com/forums/index.ph...f=107&t=491155
[/shameless plug off]
Old Jun 9, 2007 | 06:15 AM
deathsled's Avatar
you know there's a gen 2 comptech adjustable bar for sale in FS, right?
Old Jun 9, 2007 | 03:51 PM
jeggy's Avatar
yes. i saw that comptech bay in the FS section.
Old Jun 9, 2007 | 04:14 PM
gomarlins3's Avatar
Get the CT and you won't be sorry.
Old Jun 10, 2007 | 06:08 PM
jeggy's Avatar
http://cgi.ebay.com/ebaymotors/2000-2005-H...1QQcmdZViewItem
any comments about this bar?
FastUnicorn
Apr 1, 2019 02:25 AM
Xeon
Nov 9, 2016 05:20 AM
needans2k2
Aug 27, 2011 02:12 PM
award78
Feb 21, 2011 03:48 PM
nyuaznguy
Jan 15, 2010 03:51 PM
