Taming the oversteer
Old Feb 22, 2008 | 03:21 PM
pdexta's Avatar
Default Taming the oversteer
When I go to autocross I seem to have this problem keeping the front end of the car ahead of the back end of the car. I'm assuming the best way to tame the oversteer is a sway bar. I realize a comptech bar is the best option, but I'm not looking to throw that kind of money at it. I'm hoping to keep it somewhere in the $200 range. I can't seem to find stiffness figures on most of the sway bars that are available. I'd at least like to make sure what I'm buying is at least stiffer than what I'm taking off. What about the option of swapping out the rear sway bar for a AP2 bar (I'm pretty sure they're softer, I'd assume that would serve to tame the car a little as well). Any negatives to that option?
Is there anything out there that will help me out? Or should I just swap on some 185's for the front tires and hope for the best? Thanks for the advise and sorry for the noob question. I searched, I promise!
Old Feb 22, 2008 | 04:25 PM
CobraTi's Avatar
For around $200, you probably wont find an "autocross" sway bar, but could probably get a 30mm or 32mm non-adjustable bar. Would be stiffer than stock, but not as stiff as a Comptech or Gendron. I believe the 2000-2001 cars had a 28mm bar on them, could be wrong about that though. Also, if you plan on running in stock class, you cant change the rear bar. If you dont care about stock, you could try disconnecting the rear and see if that helps out.
Old Feb 22, 2008 | 04:51 PM
triumph87's Avatar
There is also the Saner bar, I believe he still makes them.
But... he is harder to reach the the president
Old Feb 22, 2008 | 09:05 PM
Random1's Avatar
[QUOTE=scottrunsxc,Feb 22 2008, 05:21 PM]When I go to autocross I seem to have this problem keeping the front end of the car ahead of the back end of the car.
Old Feb 23, 2008 | 10:22 AM
SlipAngle79's Avatar
FYI form the Faq: https://www.s2ki.com/forums/index.php?showtopic=351694
THere are a few stiffness #'s there, but the Swift is actually 87% OF the MY00-01's front bar - so 13% less stiffness than a OEM front bar from 00-01's according to Swifts website.
I am in the market for one too, for track days though. Since the he Saner is out of production, I am leaning twords the Cusco as this is the only one I could track down any data for - 72% increase over OEM 00-01 bar.
Not to jack but anyone have input on the Cusco fornt bar or any stiffness numbers on non-adj fornt bars???
Old Feb 23, 2008 | 07:49 PM
S2Kretard's Avatar
Old Feb 24, 2008 | 08:02 AM
why the retard?
Old Feb 24, 2008 | 12:10 PM
aronparsons's Avatar
Originally Posted by Random1,Feb 23 2008, 02:05 AM
What is your wheel/tire setup? What is your shock/spring setup?
Originally Posted by scottrunsxc
* Comptech SC'd * 325 hp * 201 tq *
Maybe this is part of your problem!
I know several people that autocross stock S2000s with street tires and they do not have an over steer issue. Driving style can have a lot to do with it. Be sure to use second gear. When I started on street tires I spun the car many times. I'm sure I provided some local entertainment.
Have another experienced S2000 driver try your car for a couple of runs and see what they think of the handling.
Look at your driving style first. Have some experienced RWD (preferably S2000) drivers ride along and point out any obvious driving mistakes (e.g. lifting mid-corner, not being smooth, twitchy steering).
If you're confident it's not your driving, there are various things to consider before going for a larger front swaybar (which is totally unnecessary with stock tire sizes). You can try adjusting your tire pressures to find the optimal numbers for your tires (you may be running too high/low and not utilizing all of your rubber). You should also have your alignment checked out; too little toe-in in the rear will make the car oversteer a lot.
I ran a Saner FSB a few times on my street tires (too lazy to change over to R-comps those weekends) and it induced an unmanageable amount of understeer; I was like Mr. Plow ;-)
Old Feb 24, 2008 | 06:08 PM
Random1's Avatar
I run wider front tires on the street because of the stiff FSB (comptech on full stiff).
F 225/50/16
R 245/45/16
The car handles great, well balanced.
Old Feb 25, 2008 | 04:36 AM
jguerdat's Avatar
A couple of seasons ago I ran the RE01Rs in 205/225 sizes with the Comptech on full stiff. Learned some car control because understeer was available only if I forced it...
