Tein SRC's compared
Originally Posted by boyguan' timestamp='1399695312' post='23153213
[quote name='andrewhake' timestamp='1399694294' post='23153194']
Do you thin it was possible your Evasive Specs were valved incorrectly? Were you the original owner? Most people seem to say that the Evasive specs are more compliant than the standard SRC so that is definitely interesting to hear that they were valved extremely stiff. A friend of mine who has been using the standard SRCs for many years has tried out a similarly prepped car with the Evasive Spec and said he felt they were noticeably more compliant and more confidence inspiring. But again I suppose each drivers feedback is swayed by everyone else's. Maybe I will take my Evasive Specs to PSI to have them dyno'd to see if they are valved similarly to yours.
Could be worth talking to Evasive to see if your dyno plots match theirs or are similar? It seems you were successful having Tein revalve them to a setup you were happy with so that is definitely a good thing.
Not true. Talk to a few people at t hill aka ivan and he will tell you he is having trouble setting up his suspension
I had the r2 and after countless track days of fiddling. I don't have them anymore
[/quote]
Correct. My Eibach Evasive Spec. R2 is off the shelf version but its an older model. I think the top has has been updated on the newer model. Its still capable of running 1:53.6 on BW13 with street tires. So far, I have been really happy with them but I run them with RCA's.
Something is a miss with your SRC here. I owned 2 sets of Evasive SRC and had no trouble driving them at T-Hill and BW. If Edwin says they are un-drivable, I believe him. I pinged Evasive about this so they should be looking into this...
Thanks for the feedback. I really appreciate being able to talk about proper setups on this forum. It seems like it should be expected on the R&C side of things but doesn't happen nearly as much as it should! Right now the latest thing I've been trying to tune out was some oversteer on exit at button. This feedback will be applied next time were out there. I look forward to tracking w you next time!
So obviously the car is setup to cope with the atrocious pavement we have here at southern California tracks BUT I would not suspect the tuning methodology would really change much for another region since a bump is a bump and if the track is smooth but my car can handle bumps that just means I can use more curbing
. From here on is really only my rudimentary understanding so take it with a grain of salt: Really what this setup provides is platform stability. The spring rates on the car are 900f/780lb rear and it now rides smoother than it ever did stock. The reason being is the heavy spring rates provide most of the compression resistance needed already and then you just need to control the rebound of those heavy springs. In the front you want more rebound to keep the nose from unloading too fast after braking so the car will take and hold a set. If you run too little front rebound on heavy springs like that the nose will unload too soon after turn-in. As for the rear The S2000 has so little rear travel that running too much rear rebound (like the evasives did) will cause the rear to down-jack to the bumpstops and stay there. This was born out on the evasives I ran. The idea for low rebound in the rear I THINK is to recover your travel as quickly as you can to keep the car "suspended" and preserve travel.
Honestly I doubt the dampening will change much when adding aero. The biggest change might be to my rear spring rate to help re-balance the car so a wing doesn't push it statically into the bumpstops but otherwise the idea is that if you introduce aero into a shock setup like this where the suspension is already interpreting the road without upsetting the car to a degree, now as long as you add balanced aero all it does is increase the effective traction limit. I already experience this on my lemons car when adding aero. In high speed corners with poor pavement like riverside at buttonwillow, on the evasive shocks my S2000 would buck and heave over the choppy pavement. My lemons car with more compliant shocks and aero, you could feel the suspension working furiously to keep the tires down but the chassis never moved while the car sailed over bumpy pavement. This means I never had to apply corrective inputs and could keep things smooth which meant more time on the gas and more effective use of the available traction and thus better times.
I think if you follow the shock tuning going on in the miata community (Supermiata, Miata challenge, etc) you'll find that they are several years ahead of what we are doing here just due to the pressures of more competition driven development going on, and the really fast setups (949 racing Xida suspension, FatCat motorsports etc) are all trending toward these sorts of low compression curves because they make the car easy to drive, and easy to drive fast because the car becomes more stable and thus encourages the driver to push the envelope. Obviously the exact numbers of the setup are tied to spring rates and chassis weights etc but the general idea is portable.
I look at it like this, anything that makes the car easier to drive, makes the car faster and more consistent. Period. I don't think anyone will argue with that statement.
Originally Posted by b505' timestamp='1399936457' post='23156859
This is great! Thanks for providing that data and all your research. I'm actually curious as to knowing a little more about the conversations you had with the engineer in charge of helping you dial in your S. I've heard mixed theories on biasing suspension setups toward rebound vs compression. They say most race cars are valved toward a heavily compression biased setup while street cars can be fairly neutral. I didnt know how much a modified street car would be considered a "race" setup. But overall it looks like the recommended numbers had your goal aimed at being rebound biased up front and fairly neutral in the rear.
I've found a very similar setup on my coilovers does the trick quite well (through trial and error and a notebook). What tracks did you guys design this to be ideal for? And did you happen to ask what happens when you change to r compounds or aero in the future how it might affect your suspension tuning goals?
Thanks again for sharing!
. From here on is really only my rudimentary understanding so take it with a grain of salt: Really what this setup provides is platform stability. The spring rates on the car are 900f/780lb rear and it now rides smoother than it ever did stock. The reason being is the heavy spring rates provide most of the compression resistance needed already and then you just need to control the rebound of those heavy springs. In the front you want more rebound to keep the nose from unloading too fast after braking so the car will take and hold a set. If you run too little front rebound on heavy springs like that the nose will unload too soon after turn-in. As for the rear The S2000 has so little rear travel that running too much rear rebound (like the evasives did) will cause the rear to down-jack to the bumpstops and stay there. This was born out on the evasives I ran. The idea for low rebound in the rear I THINK is to recover your travel as quickly as you can to keep the car "suspended" and preserve travel. Honestly I doubt the dampening will change much when adding aero. The biggest change might be to my rear spring rate to help re-balance the car so a wing doesn't push it statically into the bumpstops but otherwise the idea is that if you introduce aero into a shock setup like this where the suspension is already interpreting the road without upsetting the car to a degree, now as long as you add balanced aero all it does is increase the effective traction limit. I already experience this on my lemons car when adding aero. In high speed corners with poor pavement like riverside at buttonwillow, on the evasive shocks my S2000 would buck and heave over the choppy pavement. My lemons car with more compliant shocks and aero, you could feel the suspension working furiously to keep the tires down but the chassis never moved while the car sailed over bumpy pavement. This means I never had to apply corrective inputs and could keep things smooth which meant more time on the gas and more effective use of the available traction and thus better times.
. My street car handles better than s2k did, and that is with more than double hp and stock air shocks on street tires. Even with all body roll and understeer I never wondered what will do, easy to drive. Until electronics kick in thinking I am crashing
. Or what we would call good mechanical grip, something s2k did not have.Personally I think it needs to be softer, not stiffer.
Great info!
I ended up, through a convoluted process, getting a one-time *killer* deal on some brand new SRC's with 16K Swift springs, with the mindset that I would get them revalved after this season while costing less than Penske/Koni/Moton/JRZ/Ohlins.
I'll see how mine handle at Gingerman on Memorial Day.
Also, subscribed.
Also, subscribed.
