Tein SRC's compared
Old May 15, 2014 | 08:12 PM
  #61
Bullwings's Avatar
Lol - i'm looking for a set of Bilstein PSS or PSS9 now... hahaha, willing to trade my GTC-200 wing for it with a bit of cash on top.
I don't care if they're blown or leaking - just not structurally damaged.
Old May 15, 2014 | 09:14 PM
  #62
JJ7's Avatar
JJ7
Originally Posted by anorexicpoodle
You're welcome to it the next time I'm at the track with you.
Thanks! To bad I don't still have street tires. It would be a pretty good apples to apples comparison.
Old May 26, 2014 | 03:40 PM
  #63
Zwin's Avatar
Im having similiar issues with my set as well. The rear end tends to skip on turns. My DD integra with cheap function form coilovers is more easier to drive to its limits compared to my Tein EVS SRC with less effort. Here are my shock Dynos at the same settings as you had. Im going to contact Guy Ankney and see if he can help me out.
Old May 27, 2014 | 04:34 PM
  #64
anorexicpoodle's Avatar
Top Answer: 1
Did you happen to drive it on those settings?
Old May 28, 2014 | 12:45 AM
  #65
Zwin's Avatar
[/quote]
Havent driven it with those settings. Still putting my car back together. What compression and rebound settings are you at right now after the revalve?
Old May 28, 2014 | 07:16 AM
  #66
Top Answer: 1
It's on the softer side for compression between 10 and 13 from stiff, different per corner and rebound front is stiff, 3 to 5 from stiff and rebound rear is soft, so 10 to 12 from stiff but the exact clicks don't matter since the valving isn't the same. Guy set them on the dyno so all 4 produced equal curves. No corner is maxed out but none are anywhere near the middle either.
Old May 29, 2014 | 05:19 PM
  #67
suterusu's Avatar
I did a shakedown at Gingerman on Memorial Day, and the car was not as bad as I expected. I set the shocks based on this thread as a baseline and they worked pretty well, definitely not as bad as the OP. I'll post video this weekend.
Old May 29, 2014 | 11:43 PM
  #68
Top Answer: 1
Are yours evasive SRC's or regular SRC's?
If they are regular SRC's have you dynoed them? That is a data point missing from my original comparison.
Old May 30, 2014 | 11:11 AM
  #69
andrewhake's Avatar
Keep in mind that your set (and a few others) may have just been valved incorrectly. Have you sent your dynos to Evasive or Tein to verify?
Old May 30, 2014 | 12:02 PM
  #70
SHG_Mike's Avatar
If they have been valved incorrectly, why hasnt Evasive or another Tein vendor provided an example of a CORRECT dyno plot.
The specific curve is not a secret, proprietary or magic. No one can steal the curve just by knowing what it is. The magic is the internals and valving to get to that curve. Any suspension worth buying will have examples of their valving in a dyno curve.
Its a very simple solution to all of the speculating.
