Testing out G-loc brake pads
Old 06-12-2017, 11:35 AM
  #21
s2000Junky's Avatar
Originally Posted by Singh_snisen
Talk to Danny at G Loc but I think u already did?.
I did, and he couldn't get anymore in depth then saying that this is what G-loc recommended to him having a similar set up as mine as far as tire stagger and brakes. I was hoping to get some technical understanding on how this conclusion was made.
Old 06-12-2017, 11:54 AM
  #22
Ricky_Flowers_'s Avatar
The one time I decided to run DTC-70 front and rear, it made braking deep really, really hairy. I had to dial back my brake points because if I applied too much brake force, the rear wheels would lose grip, rear ABS would pulse, and funnily enough front pad wear was increased dramatically. You absolutely should be running a staggered pad compound with a square or large tire setup. When I was new to tracking my car, and was running HP+, this wasn't an issue because I would overheat the pad compound long before I ran into bias issues. HP+ are NOT track pads, and are not engineered to withstand the heat associated with repeated hard stops.
My car currently is using the stock brakes, and has G-Loc R16s in the front and R10s in the rear, using 200TW street tires (255 square setup) with around 220whp. I will be testing this setup at hot ass Sebring in July, so I guess we'll see how well G-Locs handle the heat. Most Spec Miata guys I know are using these pads and absolutely love them.
Also, an important distinction: G-Loc is NOT Carbotech. The two are completely different companies. Yes, Danny Puskar helped start and worked for Carbotech. Yes, he left and started G-Loc. Yes, the compounds may have been similar at first. They are completely different compounds now, as confirmed by Danny, and the general consensus is they're better in every way that what Carbotech offers.
Old 06-12-2017, 12:16 PM
  #23
Chibo's Avatar
Fair enough, I'll retract what I said last page and I'll be giving GLoc a shot after I kill off my Hawks.
Old 06-12-2017, 01:25 PM
  #24
Singh_snisen's Avatar
Exactly wat I wanted to explain but rob explains it better.
When i I talk to Danny he also recommended me the r12 in the rear and nothing higher.
Speed acadamy also staggers their pads on their s2000 and they talk about it too. Maybe u can check out that episode.
Old 06-12-2017, 01:27 PM
  #25
think about it. The main engineer and developer leaves carbotech and makes his own company.
Obviously he would improve on the compounds of his rivals especially if he made them for the rivals.
Old 07-06-2017, 04:50 PM
  #26
takchi's Avatar
I've used G-LOC R18 F/R and R16 F/R.
Old 07-06-2017, 05:03 PM
  #27
bgoetz's Avatar
I have been running a 10/8 setup and have zero complaints. They have worked great and have tons of life after 3 track days. The only thing that I would maybe want is a bit more modulation, I seem to overslow the car a bit when really trying to dial in my braking.
Old 07-06-2017, 07:14 PM
  #28
Got the tranny fixed. I will be testing out the r18 at buttonwillow with vtec club in 2 weeks.
Old 07-20-2017, 10:59 PM
  #29
Marloon's Avatar
I used to run the r6 for autocross and have noticed really high torque but zero modulation of the pedal. it was like an on off switch. We moved to ax6 from carbotech and that was a lot better in terms of modulation but not as high torque as the g-loc pads.
Running r16 and r12, do you guys get good pedal modulation? I ran r8 front and rear on my miata and noticed good pedal modulation. i am hoping the same for the s2000
Old 07-21-2017, 07:15 AM
  #30
s2000Junky's Avatar
I just ordered these for my Aug 5th track day, will report back.
Quick Reply: Testing out G-loc brake pads
