Testing out G-loc brake pads
Let me put it this way. Why would I not want to run R16 all around? Why would a lessor pad in the rear be better for my set up? With all else the same, I could see running a lessor pad in the rear (Maybe?) with a non stag tire set up. But im running a stock biased tire stagger. Are the OEM pad compounds staggered?
I made the mistake of running HP+ in the past thinking I would be able to use these dual duty street/track. Unfortunately they are compromised in both environments. So now i'm looking for for a dedicated track pad. Sticking to OEM/Stoptech pads for the street. I miss the bite of the HP+ on the street, but not all the dust and noise and increased rotor wear.
it all all depends on driver taste and his feel. Of course u can run r16 all around. But it all depends on how u like ur brAkes to preform. Maybe u would like the r16 all around as a better setup than the r12 rear. The best way to figure this out is u test what works best for u. Maybe u need r16 square cuz ur rear tires are massive than the fronts so it might help U
Edit: refuted on the next page
Talk to Danny at G Loc but I think u already did? Ur running massive tires so I think u should be able to handle r16 square. I would have tested this setup for u but blown trans when I was testing the r16 , I definitely needed a better rear pad as my fronts wer doing all the work. I personally am thinking of running r16 square. Btw only 30% of the brake psi goes to the rear so I see y not run the r16 in the rear.
Main reason for staggering the pads is to enter/ exit the corner faster. The best way to test this is to test wat works best for u but like u said we are all broke and don't have the resources to spend 1000$ on pads just to find the best setup.
Therfore re I recommend the r16 square for u junky as ur tires are wayyyy wider than mine and would handle the brake gs no problem.
We run different brake compounds front and rear on the track because of weight transfer during braking. The stock calipers were designed with stock performance in mind. Add big rubber up front and/or r-compound tires and you get much more weight transfer during max braking. With less weight on the rear tires you need less brake back there.
The ABS system will cover up improper brake balance but ask the S2k race car drivers running without ABS if they run the same brake compound front and rear. They typically need less brake pad bite in the rear and need a pad made for cooler operating temperature.
robrob is 100% correct... i do have abs still but have noticed running same pads front to rear the car is actually extremely loose under braking. i run a highly aggressive pad up front and a very neutral pad in the rear and the balance feels ten folds better and allow for trail braking with out losing it
Thanks for the added input on the pad bias question guys. It seems like either option could be a good one for me, but there is quite a bit of different angles to this with my car set up and my late braking habits that may favor one over the other. I do not want to over tax the rear stock brakes at the end of the day, so maybe a lessor R12 pad back there is the answer even though I'm running more rear tire then up front. I tend to ride the line on entry oversteer, so having slight more brake bias up front may be the better of the two scenarios to help with stability if I end up overshooting and have to rely on a little trail braking. I just want to try and maximize my braking ability of the car, not giving up stopping distance which is why I was leaning towards same pad front and rear with my staggered tires. When I was running HP+ front and rear on stock brakes, I never felt the rear ABS kick in, only the front, but felt very stabile under braking. Probably leaving a little on the table, but the stability is worth it so id like to stick to that generally.
