Is there a list of all the front sway bars available....
Old Mar 23, 2003 | 05:08 PM
Z06-KILLR's Avatar
Default Is there a list of all the front sway bars available....
for our cars?
I went to my first autox event with my new set up of tires and camber adjustments.....HORRIBLE!!!!!
I thought I was going to be able to do without a thicker front sway bar but after spinning once on the first run, 5 times on the second run , once again on the 3rd run and nailing 3 cones as my car sideways on the last run.....then I DEFINITELY need a thicker front sway bar.
My car runs great on street tires (205/225)....but since I went to a 225/245 setup I think the extra contact up front is definitely screwing me up.
The 245 Kumho is as wide as the 225 S02's.....
Back to the list of sway bars.....which one do you guys recommend, how much are they and how difficult is the installation? I need to get one ordered pronto!!!! Thanks!!!
Angel
Old Mar 23, 2003 | 09:10 PM
PedalFaster's Avatar
Check the archives -- the most commonly-used (but expensive) options are the Comptech and Gendron bars.
There were some breakage issues with the first generation Comptech bar; it's not clear whether or not these have been rectified in the new revision. Nationals were won with a Gendron bar last year.
The Saner bar's a new, inexpensive option, but I'm not sure if anyone's fitted one yet.
Steve
- running a 1.25" "Gendron-type" bar
Old Mar 23, 2003 | 10:14 PM
Muz's Avatar
Muz
Former Sponsor
Here's a link to some nicely priced solid 30mm swaybars also...
https://www.s2ki.com/forums/showthread.php?...threadid=110733
Old Mar 24, 2003 | 04:00 AM
NYS2K's Avatar
See also:
https://www.s2ki.com/forums/showthread.php?...threadid=108955
Old Mar 24, 2003 | 04:02 AM
Z06-KILLR's Avatar
[QUOTE]Originally posted by NYS2K
[B]See also:
Old Mar 28, 2003 | 07:24 PM
Z06-KILLR's Avatar
Got my swaybar installed......hopefully I won't embarass myself on Sunday again
Old Mar 29, 2003 | 03:20 AM
Muz's Avatar
Muz
Former Sponsor
Glad to hear it arrived on time.
Old Mar 29, 2003 | 05:22 AM
Gernby's Avatar
Former Sponsor
I use the 225/245 Kumhos on my '02 S2000 (OEM wheels, stock suspension). My 1st thought about your oversteer issue is that you may be running too much air pressure in the rear. I have found that the pressure in the rear (hot or cold) should not be higher than 32 PSI, or they won't stick. The front pressure doesn't seem to be as sensitive for me, but I try to run them anywhere from 32 to 35 PSI.
Old Mar 30, 2003 | 02:28 AM
honda9krpm's Avatar
I am not 100% clear on what the braces do
Why do you guys only recommended changing the front when you oversteer? Isn't the brace makes the car more stable and holds the tires on the road better? So wouldn't the S benefits a rear brace instead of the front?
I have 225/40/18 and 255/35/18. I tend to oversteer a fair bit on motorkhanas. What should I do or need?
Could some one kindly explain?
Old Mar 30, 2003 | 02:41 AM
honda9krpm's Avatar
I think I found the answer
the front sway bar helps stabilise the car during hard corners and thus holds the rear wheels on the tarmac better
Could someone kindly clarify this
Thanks in advance
