Thoughts on Speedbleeders?
Originally posted by cdelena
A downside to the speedbleeders is that you cannot continue to use the powerbleeder since it would require too much pressure to overcome the check valves.
I have the speed bleeders on the S2000, and it seems to work fine. I still have someone else pump the pedal, just so I can see the fluid go through the bleeder tube without any bubbles. I have bled the brakes about 6-7 times already with the speed bleeders. They came with some sealant gook that you put on the speedbleeder threads, and then dry it with a hair dryer before you screw them in.
-Doug
Gernby
119
02-14-2011 11:54 AM
onepieceluffy
78
05-19-2009 12:18 PM
