Tie-down attach points?
any trailershop can get you the right tie downs. More importantly are the hooks
Both davepk and I use the "R" hook that is listed on the page sideways posted.
They are the correct fit for the 4 tie down points that are behind the jack points. I then install the tie-downs in an X.
Front Right Tie-Down on the Car to Left Front Point on trailer, etc. make an X in the front and an X in the rear.
-Ry
-Ry
don't. I'd worry too much about bending them.
Either thru the wheels or to the tie down points. Can you not get the R clips at a local place?
If not I just ran a long tie down thru both wheels for OTC, tho you'll likely move the alignment some (toe) if you do it alot.
