time for new clutch
Old Aug 30, 2006 | 09:07 AM
robinson's Avatar
Default time for new clutch
The last two trips to the local road course have resulted in the clutch slippage in VTEC. I'm assuming that this means I need a new friction disk (aka clutch disk). Would you guys just put OEM parts back in, or would anyone go with a ACT pressure plate and use their organic street clutch disk, or ACT with OEM disk?
Old Aug 30, 2006 | 09:08 AM
payneinthe's Avatar
Are you sure it's the clutch slipping and not the inside rear wheel being lifted?
Old Aug 30, 2006 | 09:23 AM
robinson's Avatar
yes, b/c is only on the straights and only on upshifts.
I have to let the RPMs drop to about 6-6.5k (depending on gear) for the clutch to not slip.
If that is what you guys USUALY do, then I've really been beating the crap out of my clutch!
Either way...its done.
Old Aug 30, 2006 | 09:30 AM
payneinthe's Avatar
That's what I usually TRY to do. If I let it out to high, though, it just kicks the tires loose for a second. I doubt anyone is harder on their clutch and transmission than I am (I'm a horrible shifter), but mine's still going strong at 41,000 miles and tons of 7,000RPM launches and about 10-15 track days.
Old Aug 30, 2006 | 09:38 AM
robinson's Avatar
What did me in, I think, was my down shifting technique, or lack thereof. I finally realized that I was slipping the clutch in a lot vs rev matching. I spent the last track day being easier on the clutch, but I could probably still get it to slip if I wanted to.
Old Aug 30, 2006 | 10:41 AM
Nobody's Avatar
I went with ACT, am SC'd and am totally happy. Consider replacing the flywheel while you're at it, seeing as though everythings coming apart anyways.
Old Aug 30, 2006 | 07:08 PM
22calbr's Avatar
have you taken the slave cylinder out. after i did that on my ap2 my clutch slips like how your describe it. probably glazed my disc.
DownSouthWS6
Oct 7, 2013 03:35 PM
dvize
13
Feb 18, 2012 07:33 PM
ywouldi
Jul 3, 2011 10:22 AM
jpetch05
Apr 20, 2011 10:24 AM
Saki GT
Mar 17, 2010 12:23 PM
